Removing putty
    April 2008
Removing putty
Posted by smeagol the vile on Saturday, July 24, 2010 8:32 PM
I opened a kit I had started a year or so ago to find that I stoped because I had put on to much putty and covered some detail that I did NOT want removed.
how can I remove this putty without sanding it and the detail off?
    December 2007
Posted by mg.mikael on Monday, July 26, 2010 8:54 AM
What putty did you use? Testors, Squadron?
"A good plan executed now is better than a perfect plan next week." - George S. Patton
  Photobucket
    April 2008
Posted by smeagol the vile on Monday, July 26, 2010 11:05 AM
Squadron white.
I tried to fix the sceam on the top of a M3 turret and its all over the rivets
    March 2008
Posted by Killjoy on Monday, July 26, 2010 12:17 PM
Dip a q-tip in laquer thinner, and gently rub the area where you want putty removed.  You may have to let a bit of thinner soften the putty up for a minute or two if it has ben dry a while.  Work slowly, and remember, less is more with the thinner.  You don't want it dripping, or sitting on exposed plastic around the area if you can avoid it.
Chris
A veteran is someone who, at one point in their life, wrote a blank check made payable to "The United States of America," for an amount of "up to and including my life."
    September 2007
Posted by SuppressionFire on Monday, July 26, 2010 12:34 PM
Acetone (nail polish remover) is effective on uncured putty. Try a bit as it won't soften the plastic quite as fast as thinner. Worst case scenario sand flat and get the rivet gun out!
http://i6.photobucket.com/albums/y211/razordws/GB%20Badges/WMIIIGBsmall.jpg
    April 2008
Posted by smeagol the vile on Monday, July 26, 2010 1:05 PM
Ill try the laquer thinner.  I tried that with mineral spirits and it did not make a dent
    November 2004
Posted by Bronto on Monday, July 26, 2010 5:25 PM
Be careful as lacquer thinner will melt away the plastic as well as the putty.  Probably just be easier to sand away the putty and replace the rivets that are removed with it.
    March 2008
Posted by Killjoy on Monday, July 26, 2010 6:53 PM
Yeah, if you SUBMERGE or drench the plastic!  Again, use a q-tip moistened in thinner, and run the putty.
    December 2009
Posted by Harshman II on Monday, July 26, 2010 7:17 PM
Try alcohol first... If it cannot remove putty then use thinner. Becos , alcohol is not corrosive to plastic which means you can try to use as much alcohol as you want when you attempt the removal.
    August 2005
Posted by Phil_H on Monday, July 26, 2010 7:24 PM
Harshman II
Cured Squadron putty is unresponsive to alcohol. It is likely that the only solvents which will soften the putty (eg. lacquer thinners, liquid cement)  will also soften the plastic. A more expensive option (which I've not tried), you may try something like Gunze or Tamiya lacquer thinners which are formulated to be less aggressive to styrene.
