Using my Twin Tip sharpie
    November 2008
Posted by Arespontus on Sunday, September 25, 2011 5:29 PM
Hello
I read somewhere on this site that If I use a sharpie to enhance the panels on my Aircraft, it might bleed throught the grey paint from my airbrush after a couple of weeks.
If I do use the sharpie I will be using acrylic paints over top of it. Will the use of acrylic paints stop the sharpie from bleeding through the grey paint.
I want to test this out on my Revell F-14D Tomcat 1:48
Is this a wise idea to try out, Or am I just going to make a mess.
Scott
    January 2010
Posted by CrashTestDummy on Wednesday, October 5, 2011 1:43 PM
You're going to make a mess. But it's always good to test to see for yourself.
Gene Beaird,
Pearland, Texas
G. Beaird,
Pearland, Texas
    January 2006
Posted by dirkpitt77 on Wednesday, October 5, 2011 1:53 PM
   Do you have a scrap model laying around you could test it on?  Best way to be sure is to do a practice run 1st.  That's how I'd do it.
    Although, a sharpie I would think would make too "sharp" a line, if you'll pardon the pun.  Not sure you could get the blended effect you're looking for.
    "Some say the alien didn't die in the crash.  It survived and drank whiskey and played poker with the locals 'til the Texas Rangers caught wind of it and shot it dead."
    March 2010
Posted by Scorpiomikey on Wednesday, October 5, 2011 1:55 PM
Try it on a rubbish kit first.
"I am a leaf on the wind, watch how i soar"
Recite the litanies, fire up the Gellar field, a poo storm is coming Hmm
My signature
Check out my blog here.
    October 2008
Posted by oddmanrush on Wednesday, October 5, 2011 2:15 PM
Don't do it! Please don't do it! I've used a black sharpie to quicken the process of pre-shading and I paid for it...on 3 different models.
If there is any thing I preach against here, its the use of a sharpie! I used it on the panel lines prior to painting with Tamiya acrylics. At first it was Ok, which is why I was able to do this with 3 different models. But when I shot over it with a coat of Model Master Dull Coat, the sharpie stood out immediately...not sure the chemical process but it looked as though I'd sharpie'd OVER the OD green! The other models I hadn't clear coated eventually showed sharpie bleeding through...
So yeah, I don't recommend it at all!
HERE is a link to a previous thread regarding this...there is a pic of a ruined model, similar to my experience, after a dull coat...
Regardless, dull coat or not, I'd stay away as they do tend to bleed through...
Jon
My Blog: The Combat Workshop
    December 2004
Posted by panzerpilot on Wednesday, October 5, 2011 2:26 PM
Use the sharpie for tracing along oil lines in a wheel well. No no on the pre-shading!!
-Tom
