I use a variation of a couple of the techniques mentioned here.
I use plain, ordinary cheap painters masking tape from Walmart--usually the yellow-tannish kind, since it seems more flexible than the blue kind. I cut this into very thin strips, usually much longer than needed so you've got something to hold onto, on each end.
I mask around the inside edges of the "glass," using a sharp xacto blade to trim on the model. Then I use MicroMask to fill in the centers. The result looks like this.
[View:/themes/fsm/utility/:550:0]
As you (hopefully) can see, when the strips are cut narrow enough, they go around curves pretty well.
And after painting and removal, the final result looks like this.
This method is just as tedious and time-consuming as others have mentioned. One of the joys of kitbuilding.
Good luck. And practice, practice.
