Siimple Green as a paint stripper
    July 2011
Posted by prush on Monday, November 14, 2011 4:54 PM
What paints will Simple green "strip"
a) Acrylic
b) Enamel
c) Lacquer
d) ALL OF THE ABOVE
thanks
phil
    October 2008
Posted by padakr on Monday, November 14, 2011 5:58 PM
Phil,
Acrylic and enamel for sure.  I don't know about lacquer.
Paul
Dre
    June 2007
Posted by Dre on Friday, November 18, 2011 3:12 PM
Simple Green will absolutely remove MM and Tamiya acrylics (some paint might hang on in tight recesses, but I use an old soft-bristle toothbrush to get that out) and I've had decent removal of some MM enamels.
One thing I've noticed- the longer the paint has cured the harder it might be to remove, especially the enamels.
    August 2011
Posted by GreenThumb on Sunday, November 20, 2011 6:11 PM
Super Clean is far better. It is a little more caustic but it is still biodegradable.
I think it's about $14 a gallon at Walmart. Strain out the paint particles in it after use and use it over and over.
    January 2013
Posted by desertevac on Saturday, January 12, 2013 6:50 PM
How does this affect polystyrenes. I have a coupel older models I would like to try this with. I am trying to get back into the hobby after a way too long break.
    April 2012
Posted by Dodger57 on Saturday, January 12, 2013 11:29 PM
I've had no luck stripping lacquers with Simple Green or the purple stuff, you can soak for days and nothing - however you can wipe the lacquer off with 91% alcohol fairly easily.
