rigging
    December 2010
rigging
Posted by modelista on Wednesday, November 30, 2011 10:50 AM
Wich is the best material for rigging. I read about metal wire, what's that? And for the airplanes and tanks antennas?
Thanks,
Modelista
    August 2004
Posted by four-star on Wednesday, November 30, 2011 12:28 PM
It's more down to personal preference really as there's lots of different ways, but the scale also comes into things as well.  You can use stretched sprue which is where you heat a spare bit of sprue over a candle and then stretch it out when it goes soft.  You can get any thickness you like by stretching more or less and so is good for multiple scales.  You could also use fishing line or nylon thread which are also available in different colours and thicknesses.  Other people on here will have other ideas as well
    June 2010
Posted by DoogsATX on Wednesday, November 30, 2011 12:42 PM
What kind of rigging are you referring to? IMO the application leads to different techniques.
For aircraft aerial wires, I use stretched sprue. For biplane rigging, I use a slightly elastic monofilament called Uni-Mono combined with microtubing-and-metal wire eyebolts.
On the Bench: 1/32 Trumpeter P-47 | 1/32 Hasegawa Bf 109G | 1/144 Eduard MiG-21MF x2
On Deck:  1/350 HMS Dreadnought
    December 2010
Posted by modelista on Wednesday, November 30, 2011 3:30 PM
Model ships rigging also. Thanks for your promtly answer,
Posted by Don Stauffer on Thursday, December 1, 2011 9:29 AM
Depends a lot on scale.  The biggest problem is that in smaller scales, one cannot find thread of small enough diameter to match the size of rigging on the prototype.  You need to find something that looks smaller than it really is.  The way to do that is the translucent/transparent monofilament thread, which can be found in pretty thin diameter to start with.  You need something like this on 1:350 and 1:700 ships.  For larger ships, especially sailing ships, which used actual fiber ropes, thread is fine, and available in a number of diameters.  Model Expo carries threads aimed at rigging sailing ships.
For aircraft, 1:72 can benefit from the monofilament thread.  1:48 and 1:32 can use thread.  A medium gray simulates stranded stainless wire very well.
The big drawback to monofilament thread is that it is very stiff, and hence hard to tie knots in.
Many models rigged with actual wire have rigging that appears oversized.  While very thin wire IS out there, it is hard to find these days.  Fewer hams and electronic hobbyists wind their own coils now, so finding #35-#40 wire is getting very hard.  I have salvaged radios and old TVs, stripping wire from interstage transformers to get fine wire.  You won't find fine wire like that at a hardware store (or even Radio Shack these days).
