Tamiya F4F-4 wing guns
Posted by wjbwjb29 on Sunday, January 15, 2012 1:17 PM
Hello;
I am starting the Tamiya F4F-4 Wildcat and if I saw this before gluing the wing sections together I would have fixed it then. The guns are splt at the wing center line and once glued together dont look very good. I am going to atempt to drill them out but could use any feedback available. I would like to but brass tubing in if I can find the right size. Any help would be appreaciated.
Bill
On the Bench:   Trumperter Tsesarevich on deck Glencoe USS Oregon
    September 2011
Posted by OMCUSNR on Monday, January 16, 2012 7:45 PM
Might be a little late, but...
http://store.spruebrothers.com/148-aires-f4f-4-wildcat-gun-bay-set-tam-kit-4094-p7892.aspx
Also, there are aftermarket brass barrels available in most scales.
Reid
Grumman Iron Works Fan.
"Don't sweat the small stuff.  And.... it's ALL small stuff, until you hear INCOMING!!!!!!"
    October 2004
Posted by jschlechty on Wednesday, February 8, 2012 7:08 PM
I usually use hypodermic needles I get used from a friend who is a horse vet.  Working on the bigger animals he uses a lot bigger needles than most other docs or vets.
There is also a company called (IIRC?) Mini-meca (sp?).  It seems like Sprue Bros carrys some of their tubes.  They have lots of tube shapes and sizes that can be made into gun barrels.
