Lost prop hub
    January 2012
Lost prop hub
Posted by busman13 on Tuesday, January 31, 2012 4:51 PM
I'm building a JU-88 Italeri 1/72 and lost one of the prop hubs. What would be my best course of action to get another one? Attempt to make another from the one i have. make some type of mold. Would love to here any ideas.
                     Thanks John
Posted by Don Stauffer on Wednesday, February 1, 2012 8:07 AM
Two things to try before you cast it yourself.  First, try to get replacement from Italeri.  Second, see if there are any aftermarket props available.  If these don't work, and you have to cast, here is my recommendation.
I am a big advocate of the J-shaped pouring sprue.  You do NOT want to have resin entering top of mold, which will interfere with air leaving and seeking vent.  Bend a J out of wire or something.  Attach existing prop hub to top of the short leg of the J.  Then glue a smaller vent tube from the top of the hub parallel to pour sprue up to same level as top of pour sprue. Suspend this contraption in a tube that will contain the mold and pour the mold material.  Slit the mold, remove the pattern, replace the mold in the casing and pour resin.
