Washing a new kit
    October 2010
Washing a new kit
Posted by litemup17 on Friday, February 17, 2012 9:25 AM
I am getting back into the hobby after many years of being away from it, my question is, is it necessary to wash a new kit with warm soapy water before assembly, and should a kit be primed before assembly, thanks for any help
    September 2003
Posted by checkmateking02 on Friday, February 17, 2012 9:31 AM
I always wash a new kit.  It only takes water and dish detergent.  If I don't, I usually pull some paiint off after masking.  I also wash them again after sanding and handling them--right before painting.  Oils from the fingers can interfere with paint adhesion, too.
I don't prime.  Others do.  I think of the first coat of paint as the primer, but I use laquer for thinning, and that's fairly "hot."  If you are using acrylics, maybe you should prime first.
Good luck.
    January 2009
Posted by paintsniffer on Friday, February 17, 2012 9:34 AM
The kit makers say to wash the things in the instructions.
I have over 100 kits to my credit and I have yet to wash 1 polystyrene kit. I do wash resin because it seems to always feel greasy to me.
However, I do use a lacquer primer.
Excuse me.. Is that an Uzi?
Posted by Don Stauffer on Friday, February 17, 2012 9:37 AM
I'm the opposite from Checkmateking. I almost always prime, but do not always wash.  I probably should, but frequently do not. I always wash resin, and occasionally do styrene.  I generally use Krylon primer, which is pretty aggressive.  That may be why I get away without always washing.  Washing is in general a good thing, as long as you rinse well, but if you prime with a good primer you may be able to get away without washing, though I hate to recommend that as a general rule. It is a case of "do what I say, not what I do!"
    October 2010
Posted by litemup17 on Friday, February 17, 2012 9:47 AM
Thanks for the advice
    March 2010
Posted by Hercmech on Friday, February 17, 2012 9:48 AM
Funny...I just had this debate with myself last night.
I usually don't wash, (I do primer) but after the last kit I did when the primer came up (Valeijo) I decided that I would give washing a try, I can say that I could really feel a difference on the plastic after I washed. It seemed to take away some of the "slick" feel.
I will see how much that 10 minutes really helped.
13151015
Posted by Tojo72 on Friday, February 17, 2012 9:48 AM
I don't wash my plastic kits,nor have I primed them and I have never had any problems. I have washed resin parts and friul tracks.
    April 2005
Posted by carsanab on Friday, February 17, 2012 9:50 AM
I also wash my kits.....just be careful which soap you use...some of those "moisturizing" soaps can leave a residue....happened to me once,,,,drove me crazy until I figuered it out....when I would brush paint the paint would pull off...
good luck..
C
 Photobucket
    January 2009
Posted by Griffin on Friday, February 17, 2012 10:01 AM
I always wash my kits with dish soap and water. It only takes a few minutes and I don't see a reason to risk an easier finish.
In another current thread someone mentioned cleaning with Windex. I'm going to try that next time as well.
    April 2005
Posted by carsanab on Friday, February 17, 2012 10:18 AM
another thing is to wipe it down with alcohol especially after sanding....
 Photobucket
    March 2010
Posted by Hercmech on Friday, February 17, 2012 10:21 AM
carsanab
That has always been my shortcut to washing
13151015
    February 2007
Posted by mitsdude on Friday, February 17, 2012 10:40 AM
Washing?
Styrene no
Resin, Vinyl yes.
 Priming?
Yes, everything.
    February 2011
Posted by gunner_chris on Friday, February 17, 2012 11:02 AM
So for those that wash their kits, do you wear gloves when handling?
I washed a kit for the first time last night, when it dried I was curious about handling it.  I held it by the sprues but obviously I can't do that when assembling.
    December 2004
Posted by panzerpilot on Friday, February 17, 2012 11:09 AM
I always wash my kits. I use warm, lightly soaped water (dawn dish soap). I have come across situations in the past where there was a very small amount of oily residue on the kit from the moudling. I dry it the best I can, so there are few spots.
When handling, I wear a cloth glove or, at least wash my hands really well. Oil on your fingers can cause problems.
-Tom
    March 2010
Posted by Hercmech on Friday, February 17, 2012 11:10 AM
gunner_chris
I wear nitrle gloves during all aspects of the build. I have tried not weaing them but I always leave a finger print if I don't
13151015
    April 2005
Posted by carsanab on Friday, February 17, 2012 11:35 AM
usually the gloves come out when AB painting....before that I regularly use the alcohol....on the kit as well as the builder...
 Photobucket
    December 2004
Posted by panzerpilot on Friday, February 17, 2012 11:45 AM
carsanab
That would make an interesting GB. "2012, buzzed builder alliance".
One reason I wear gloves, is all the interesting colors I get all over my hands if I don't.
-Tom
    September 2006
Posted by the Baron on Friday, February 17, 2012 12:04 PM
litemup17
I do, but I have moved from using liquid soap/dishwashing liquid, to using a couple drops of the de-greaser Super Clean.  I started using SC last year, first to strip chrome from plated sprues, and then to remove paint.  I noticed that the plastic was cleaner than I had ever seen it.  You could feel the difference on the surface.  Then it occurred to me to use SC when cleaning the sprues prior to construction, and I switched over.
    October 2011
Posted by kaiyudsai on Wednesday, February 22, 2012 9:06 AM
I always keep alcohol handy and I frequently wash my hands with it while Im doing alot of painting and detail work.....   I use nitrile gloves when the main paintjob begins..... including during the micromesh polishing between priming ...
On the Bench : Ukrainian Flanker, Ju-87B Luftawaffe, Mi-24 (Trumpy scale)
Posted by Anonymous on Wednesday, February 22, 2012 9:11 AM
litemup17
Washed: No...
Primed: Yes...but usually after assembly of most components...
    October 2010
Posted by tbhalomaster on Sunday, March 11, 2012 6:30 PM
I think it depends more on the paint that you use. From my knowledge, enamel and laquer paints have strong solvents that are able to cut through grease, and adhere well without primer (for the most part). However, acrylics generally have weaker solvents, so they are more suceptible to oils, so a clean surface is ideal.
Personally, I always wash my kits (no reason not to, really) by letting them soak in soapy water for an afternoon. Then, I let them airdry. I rarely prime, though, because I find that the Humbrol enamels I use adhere well for my purposes. I also never wash my model during the build. I use tack cloth before I paint, though.
Good luck!
Posted by Bish on Sunday, March 11, 2012 6:34 PM
Tojo72
Ditto with regards to plastic. As to metal and resin, i have never washed or primed these either and have not had any problems.
    July 2010
Posted by robtmelvin on Monday, March 12, 2012 10:04 AM
In the three plus years I've been back in the hobby I've never washed a styrene plastic kit and never had an issue with paint sticking.  Now, that having been said, I do use enamel paints, which I think do adhere better.  I do, however, wash off my PE with mild soap and water and then give each fret a bath in vinegar to etch it a bit to give it a little "tooth" for the paint to adhere to.  Resin is a totally different matter.  If I'm using a resin replacement part I always wash it with Plastic Prep and then follow with a rinse and a soap and water rinse.  I started doing that after an experience with resin replacement parts where they did not want to take and hold even enamel paints.
Bob
Just launched:  Revell 1/249 U.S.S. Buckley w/ after market PE and guns.
Building: Italieri 1/35 P.T. 596 w/ Lion Roar PE.
    May 2010
Posted by Glorfindel on Thursday, March 15, 2012 4:48 PM
I wash only because I know it can't hurt and takes very little effort.
    September 2006
Posted by the Baron on Friday, March 16, 2012 12:32 PM
Hi, Glorfindel!  Are you the same Glorfindel from the Nerd Herd?  I'm the Baron over there, too.  Welcome to FSM!
    June 2008
Posted by Hans von Hammer on Friday, March 16, 2012 4:26 PM
Manstein's revenge
 litemup17:
Washed: No...
Washed? No, not in over 2000 kits, with the exception of maybe a half-dozen resin ones..
Primed, No, generally.. Sometimes,  Yes, but only if the plastic is dark-colored like Navy Blue or Olive Drab and the finish is going to be a light color, and then only after about 95% of it is assembled.. NEVER prime the parts on the sprues, you'll be scraping more paint than you ever imagined possible in order to glue parts together..
Other exceptions to the "No Priming" is metal parts, resin parts, and figures...
dmk
    September 2008
Posted by dmk on Sunday, March 18, 2012 9:35 PM
Glorfindel
Exactly.
The day before I start working on it, I wash every kit with some Dawn or Simple Green, rinse in warm water and let the sprues dry overnight in the dish drain.
Before I paint, I wipe the parts down with alcohol and a lint free cloth.
