First time scribing panel lines
    December 2011
Posted by TroyH on Tuesday, March 27, 2012 11:43 AM
Hi all,
I'm attempting my first panel scribing. I have a cheap Lindburg A-4 Skyhawk with fairly simple panel lines. My question is how do you check if you are doing them correctly? Do you prime, scribe, prime etc.. or what?
Thanks in advance!
Troy
    March 2010
Posted by Nathan T on Tuesday, March 27, 2012 12:30 PM
scribe, sand, scribe...I Run liquid cement along each line after you've sanded them down. If you think you need to scribe more to make the line deeper, don't. Its easy to end up with a trench looking line. It takes lots of practice(for me anyway), and a good too. Some are just junk. I use a Bare Metal scribe and I like it.
    December 2011
Posted by TroyH on Tuesday, March 27, 2012 12:36 PM
what's the purpose of running liquid cement along each line?
dmk
    September 2008
Posted by dmk on Monday, April 2, 2012 8:42 PM
Dissolve the rough remnants of plastic on the edges of the scribed lines.
    January 2009
Posted by fermis on Tuesday, April 3, 2012 3:29 PM
I scribe with a heavy sewing needle, chucked in a pin vice, and use a thin (flexable) piece of metal for a straight edge. I start out by dragging the needle, slowly and softly along the straight edge, then drag it along a couple more times, applying a little more preasure each time. 5-6 "drags" usually does the trick. I then sand over the lines with 400 grit, run the needle through again, sand, needle, then sand again, using lighter grit. To get all the sanding dust out of the lines, I run a polishing disc(Dremel) over them, also polishing the plastic at the same time.
    April 2005
Posted by wing_nut on Sunday, April 8, 2012 9:01 AM
I use  some different things to scribe the line.  For the clean up I take a toothpick and, at an angle, take a slice off with a sharp hobby knife.  Run the little "chisel"  just created back and forth in the grove.  Just "abrasive" enough to clean and smooth the groove.
Marc
