What to use to cut apart canopies
    October 2009
Posted by Khalee2 on Wednesday, May 2, 2012 1:39 PM
Just what it says I used the smallest saw I had but I ruined it as it cut way too much out.
I am wonder tho Are these photo etch saws any good for that sort of work or would a very fine jewelers saw work better?, or is there any other method of cutting canopies apart without destroying them?.
    January 2007
Posted by Gigatron on Thursday, May 3, 2012 6:11 AM
The JLC saw will be your best bet
http://umm-usa.com/onlinestore/product_info.php?products_id=35&osCsid=a7aa25c741666cc64ab89b6989bbb196
The saw blade has two sets of teeth on it - make sure to use the finer set to cut the canopy.  Fill the canopy with blue-tac or silly putty, or some other non-permanent putty (like used for hanging posters),  The putty will support the canopy and help you to see the frame lines, as well.  Go slow and you'll be fine.  I do it all the time on 1/72 planes.
-Fred
    July 2009
Posted by Back to the bench on Sunday, May 6, 2012 8:45 AM
The model car folks deal with this often (opening doors, trunks etc). Here is a pretty lengthy discussion on the topic. I have not tried it yet but know some guys that swear by the sewing thread method.
Gil
    September 2011
Posted by OMCUSNR on Sunday, May 6, 2012 4:16 PM
These:     http://www.ottofrei.com/store/home.php?cat=1139  are a little on the high end, but anything similar will work well.  I live by a good jeweler's saw.  Fine blades break easily, so remember - slow is faster.  Get into a good rythm, and go slow.
Reid
Grumman Iron Works Fan.
"Don't sweat the small stuff.  And.... it's ALL small stuff, until you hear INCOMING!!!!!!"
    November 2008
Posted by plasticjunkie on Friday, May 11, 2012 5:35 AM
Gigatron
Ditto Excellent product. The blade is paper thin and gets into very tight spots.
 GIFMaker.org_jy_Ayj_O
    January 2006
Posted by RedCorvette on Friday, May 11, 2012 6:28 AM
I also will use a strip of blue tape as a cutting guide along the molded frame line.
Go slow and let the saw blade do the work.  Remember that clear parts are more brittle; I've cracked pieces when I've applied too much pressure.
Mark
FSM Charter Subscriber
Posted by VanceCrozier on Friday, May 11, 2012 6:57 AM
Has anybody tried scribing along the frame edge with (?) tip of an exacto blade, sharp needle or something similar?
On the bench: Airfix 1/72 Wildcat; Airfix 1/72 Vampire T11; Airfix 1/72 Fouga Magister
