A different PE adhesion question
    June 2009
Posted by jimbot58 on Monday, December 24, 2012 1:35 AM
I say different as I have a set that is multi-layered with a plastic film. So it will go: kit part - film - PE part - film - PE part. I usually set PE with CA, and then seal all the edges with Future. I fear to use the CA with the addition of the plastic film. (It might be acetate, I don't know.)
On my workbench now:
It's all about classic cars now!
Why can't I find the "Any" key on my keyboard?
    July 2008
Posted by jeffpez on Monday, December 24, 2012 5:34 AM
I've had no problems using white glue with PE plus it shouldn't discolor the clear acetate. If the glue is too thick for your purposes it can also be thinned with water.
    June 2009
Posted by jimbot58 on Monday, December 24, 2012 7:54 AM
Cool! I was thinking white glue, but I wanted to see whate somebody else thought! Thanks!
Posted by Don Stauffer on Monday, December 24, 2012 8:45 AM
I often use white glue (usually thinned a bit) for attaching PE anyway. Gives me more setting time to reposition piece, and it leaves less effect on the surface I am applying the PE to if I smudge adhesive beyond extent of part.
    March 2010
Posted by Nathan T on Monday, December 24, 2012 9:39 AM
White glue or Future.
Posted by gregbale on Monday, December 24, 2012 10:22 AM
Nathan T
Agreed. As long as there's no stress involved structure-wise, Future works a treat. Plus, it's foolproof as far as lining up the instrument faces with the holes.
Greg
George Lewis:
