Masking NMF's with wet tissue?
    January 2006
Posted by dirkpitt77 on Thursday, January 17, 2013 3:31 PM
   I can't for the life of me remember where I read it, but I remember reading about a technique where wet tissue or paper towel is used to mask panels on an NMF built so you can airbrush differing panel colors without having to worry about tape pull-up. Is anyone else familiar with this technique, and can  you corroborate what I read?  I'm interested in trying this on my 1st NMF build.
--Chris
    "Some say the alien didn't die in the crash.  It survived and drank whiskey and played poker with the locals 'til the Texas Rangers caught wind of it and shot it dead."
Posted by Texgunner on Thursday, January 17, 2013 3:47 PM
Chris, I believe the material used is newspaper, cut into shape first and then dampened, perhaps with a "mister".  It has also intrigued me but I've never used it, yet, that is.
Gary
"All you mugs need to get busy building, and post pics!"
    July 2004
Posted by stikpusher on Thursday, January 17, 2013 3:48 PM
I do recall reading something similar. Testors used to have brochures with hints and tips for their Metalizer line on the display racks. In those pamphlets, they recommended the use of wet newspaper for masking for the reason that you listed. I would presume wet tissue or paper towel to be a variation of that technique.
U is for URANIUM... BOMBS!
N is for NO SURVIVORS...
       - Plankton
LSM
    January 2006
Posted by dirkpitt77 on Thursday, January 17, 2013 5:42 PM
Ahh....you guys might be on to something there. Dorkfish, the fiber issue does make sense.  Maybe some experimenting is in order.  Thanks and keep the comments coming if ya got 'em!
    January 2012
Posted by Misty on Thursday, January 17, 2013 8:05 PM
Never used it for masking before, sounds good. I have used it in wheelwells etc though and it worked well.
Posted by Don Stauffer on Friday, January 18, 2013 9:29 AM
There are several other materials that I know folks have used for masking over NMF (like Alclad).  They include 3M post-it notes, or frisket paper/film, both very low tack.
    June 2010
Posted by DoogsATX on Friday, January 18, 2013 10:05 AM
Post-its work great if they have a perfectly flat surface, but they're stiff enough that they'll pull up over curving contours (say lengthwise over a wing). Since I do my NMFs with Alclad, I use heavily de-tacked Tamiya tape and it works great.
Newspaper and tissue paper (the gift-bag kind, not kleenex) would both probably work quite well over more fragile NMF finishes.
On the Bench: 1/32 Trumpeter P-47 | 1/32 Hasegawa Bf 109G | 1/144 Eduard MiG-21MF x2
On Deck:  1/350 HMS Dreadnought
Posted by Don Stauffer on Saturday, January 19, 2013 10:15 AM
Yeah, for post-its you need to use two for a curved surface, with taped edge reversed, and sometimes even a bit of scotch tape to hold the two together.
    January 2012
Posted by scapilot on Friday, May 31, 2013 6:24 AM
Ive used wet paper towels / napkins / toilet paper to mask off wheel wells, and cockpits in the past.  They work really good provided you get enough stuffed in there to where you can mold and form all the way to the edges, but even then you typically have to go back and touch up bits and pieces here and there.  The newspaper could probably work the best without the risk of leaving any fibers behind, but NMF are a bit tricky, as they're so easily fouled up if you're not careful.  I'd say seal your paint job in with Metalizers first before you attempt to go and add any foreign substances to them.  Kind of just a free added insurance there.
    January 2014
Posted by Silver on Wednesday, April 2, 2014 11:25 AM
Tamiya masking tape is what I use.When using any kind of tape see if you can place the tape on the palm of your hand several times before applying to the surface.Go real slow when you remove the tape and at an angle.
    January 2014
Posted by Silver on Wednesday, April 2, 2014 11:30 AM
When using newspaper make sure to use enamel paints.Water base paints will moist through and the carbon stain will appear .Disaster 101.
