Halo around washes
    August 2012
Halo around washes
Posted by JMorgan on Monday, January 28, 2013 2:37 PM
How do you get rid of the halo of pigment around washed areas?
    November 2004
Posted by Bronto on Monday, January 28, 2013 2:38 PM
try using a q-tip and the thinner for the wash to remove it.  If you apply the wash over a gloss surface, this shouldn't happen.
    September 2003
Posted by checkmateking02 on Monday, January 28, 2013 3:03 PM
If you are using acrylics for the wash, I found it works to dampen a small paint brush, and sort of  stroke and feather at the halo until it disappears.  For stubborn situations, dampen the brush with windex or other proprietary window cleaner.
Don't let the wash sit too long, or it will become unremovable by any means or methods.
Good luck with it.
    August 2005
Posted by Phil_H on Monday, January 28, 2013 5:46 PM
If you are using an oil-based wash, you can minimise the formation of "tide marks" by wetting down the area slightly with clean thinner before applying the wash.
    April 2009
Posted by Cadet Chuck on Monday, January 28, 2013 8:37 PM
