Best paint for washes?
    October 2013
Posted by chops1sc on Thursday, October 17, 2013 6:56 PM
So I'm trying to figure this whole washing thing out. I see guys using artist oil. I've seen enamels used. And today I spoke with a co-worker who uses craft paint! I know everyone will have a favorite but what I want to know is what are the pros and cons of using the different types?
I tried to make a wash with some cheap artist oil and paint thinner and it didn't really torn out like I hoped. I will be trying some craft paint what I already have just to see if it works. Any help is greatly appreciated!
Tags: washes
https://www.flickr.com/photos/32068090@N07/albums
    December 2011
Posted by Chrisk-k on Thursday, October 17, 2013 9:00 PM
Good artist oil (e.g., Winsor & Newton) + Mona Lisa mineral spirits.
Iwata HP-CS | Iwata HP-CR | Iwata HP-M2 | H&S Evolution | Iwata Smart Jet + Sparmax Tank
    June 2010
Posted by montague on Thursday, October 17, 2013 11:09 PM
Humbrol enamel paint and enamel thinner. Same as MIG washes.
    June 2012
Posted by Compressorman on Friday, October 18, 2013 10:30 AM
Chops, did you first put a gloss coat on whatever you were using the wash on? This is pretty much a must-do imo.
    December 2006
Posted by Jester75 on Friday, October 18, 2013 10:48 AM
I use a custom water based type mix applied over a lacquer gloss coat.
I probably fill that container you see next to the ink  with 1/3 ink and 2/3 water with a drop ir two of dish soap added to break that surface tension. Hobby Lobby carries several different colors of this type of non-waterproof ink. I can do the entire craft and let it completely dry and remove it using a slightly dampened q-tip or a small folded square of tissue.  I have washed at least 5 builds using the batch in the smaller container and its not even half empty. The bottle of ink runs less than 3 bucks at Hobby Lobby and with a 40% off coupon even less than that!!
On armor, I use Winsor and Newton oils like everyone else and usually apply them over an acrylic base.
Eric
    October 2013
Posted by chops1sc on Friday, October 18, 2013 3:04 PM
I put a coat of Pledge on the model before doing the wash. I think the thinner I used just isn't the right type for the oil paint I have. I will try a different thinner on my next one.
Thanks for the replies!
