Stripping paint
    October 2020
Stripping paint
Posted by Bronco Billy on Wednesday, December 30, 2020 10:13 AM
I have a car body with extensive customizing that I got with a box of parts. I would like to use the body with the modifications,but I don't know what the body filler is. Does anyone know of a way to strip the paint and not destroy all the custom body work?
So many kits so few hours in the day
    April 2020
Posted by Eaglecash867 on Wednesday, December 30, 2020 10:32 AM
Isopropyl alcohol at 91% or better is what I use for stripping paint.
"You can have my illegal fireworks when you pry them from my cold, dead fingers...which are...over there somewhere."
Posted by Tojo72 on Wednesday, December 30, 2020 10:44 AM
Eaglecash867
Will that strip enamel or Lacquer also
    October 2020
Posted by Bronco Billy on Wednesday, December 30, 2020 10:47 AM
[quote user="Tojo72
Eaglecash867
[/quote]Will that not loosen or destroy the unknown body filler material under the paint?
    September 2012
Posted by GMorrison on Wednesday, December 30, 2020 10:55 AM
I use a product called "Chameleon" that I bought from Squadron back in the ice ages. For some reason it just keeps on working.
Bill
    April 2020
Posted by Eaglecash867 on Wednesday, December 30, 2020 1:19 PM
Tojo72
It will completely remove enamels.  It also removes lacquers, but some of the darker lacquers will leave a stain on the plastic...that's easily covered up by a new coat of primer and paint though.  Model Master flat black lacquer left a stain on the light grey plastic of my F-16CJ engine interior, but that's the only lacquer I've tried that wasn't completely removed.  Everything else has come off completely with soaking and a little scrubbing help from a cheap electric toothbrush.  Even removes my favorite primer, the Tamiya grey primer.
    April 2020
Posted by Eaglecash867 on Wednesday, December 30, 2020 1:23 PM
Bronco Billy
Can't really predict if it will or not.  It depends on how well the filler is bonded with the plastic.  If its a polyester resin type of filler like Bondo, I'm pretty sure it wouldn't be able to hurt it.  Epoxy fillers like Milliput should also be OK.  But, no guarantees since the material is unknown.
    September 2006
Posted by the Baron on Wednesday, December 30, 2020 2:19 PM
Bronco Billy
I use the automotive de-greaser SuperClean (formerly a Castrol product, now its own brand).  I get a gallon jug at Walmart for eight bucks and change.
It strips paint and doesn't harm styrene, resin (that I've seen so far), nor metal.  It will soften adhesives like 2-part epoxies, so that a piece can be pulled apart.
Without knowing the material the bodywork is made of, I can't say whether SuperClean will attack it.  But you can always use it in stages and see.
I use glass jars of various sizes to soak pieces I want to strip.  The paint softens and starts to dissolve into solution in about 2 minutes.  The longer you let the piece soak, the more paint comes off.
I also use it to spot-strip areas on a model when I can't or don't want to soak the piece.  I use an old paintbrush to apply SuperClean to the area to be cleaned.
What's great about SuperClean is that you can use a batch over and over, so it goes a long way.
Hope that helps!
Best regards,
Brad
    October 2019
Posted by Tanker-Builder on Wednesday, December 30, 2020 6:50 PM
Bronco Billy:
 You've gotten some good advice. If it was done with the old formula Testors Body putty it may hold.I f you can test a non critical area and see. If the filler gets sticky STOP!
    December 2020
Posted by TheDemiGod on Thursday, December 31, 2020 12:15 AM
Easy Off Oven cleaner in yellow can
Posted by Don Stauffer on Thursday, December 31, 2020 9:03 AM
I use Purple Power cleanser in spray bottle.  Takes off both acrylic and enamel.  Never tried it on lacquer.  I also use it for cleaning my AB jars.
    September 2006
Posted by the Baron on Thursday, December 31, 2020 11:45 AM
TheDemiGod
I used to use oven cleaner, before I heard of SuperClean.  The biggest drawback to oven cleaner is that it is a once-and-done product, you really can't use a batch of it more than once, once you've sprayed it.  That, and it's a lot more caustic than SuperClean; you really need to use it in a well-ventilated space and wear gloves (though many probably do not).  It's odd, because an active ingredient in both products is lye.  But SC isn't nearly as caustic as oven cleaners.
It's still a good idea to have ventilation when using it, too, though I don't always do that.
    April 2020
Posted by Eaglecash867 on Thursday, December 31, 2020 12:34 PM
the Baron
Oven cleaner also chemically modifies the plastic and makes it brittle.  Its the ammonia in it that has that effect.
    December 2020
Posted by TheDemiGod on Thursday, December 31, 2020 1:38 PM
True on the smell. That's why I let it sit in a covered container overnight to do its work. Then I rinse and rinse again. Let dry and clean again with alcohol.
    October 2020
Posted by Bronco Billy on Friday, January 8, 2021 7:49 PM
Thank you for all the suggestions. I have used all of them,brake fluid and pine-sol included to strip paint. I'm going to try super clean first in a clear container so I can watch it. Again thank you all for your suggestions.
    November 2008
Posted by plasticjunkie on Thursday, January 14, 2021 6:10 AM
I forgot where I read about the use of Simple Green  for this very same application. As I recall the model was soaked overnight and safely stripped the paint.
 GIFMaker.org_jy_Ayj_O
