How does one determine build/paint order?
Posted by Anonymous on Wednesday, August 24, 2005 6:54 PM
This maybe the "newbiest" question posted here, but I couldn't find the info anywhere. How do you go about determining what parts to paint on the sprue and what ones not to? Also, Is it necessary to use a primer coat on all the parts before painting? I will being using an airbrush on the large stuff and for the camo pattern and stripes. The kit I'm building is a 1/72 scale Hasegawa Spitfire Mk VIII. Any information provided is appreciated. Thanks, Basstech.
    May 2003
Posted by styrene on Wednesday, August 24, 2005 7:27 PM
Personally, I think this one has as many answers as there are modelers and available kits. Not trying to annoy or offend, but there is no fast, pat answer. You're going to have to experiment, as well as gain experience to determine what works best for your situation. In terms of primer, I think that sometimes primer is indicated especially after filling and sanding. Priming will help point out those areas that still need a little work before you lay on the topcoat. In addition, if you're going to spray a light color (say a bright yellow on a leading edge, or white on a landing gear strut, or a bright red on a spinner or rudder), first prime the area to be painted. You might want to use a white primer for the yellow and red areas, and a light gray for the strut. In addition, I never paint any part on a sprue. I always cut it off, prep it (sand, fill, remove seam, etc.) then mount the part according to the instructions, or set it aside on a piece of tape for later painting. I'll mount all the pieces on the tape that are to be sprayed the same color, spray them, let 'em dry, and mount on the kit. If necessary, after mounting, I will use a really small brush to touch up any goof-ups.
Hope this helps a little.
Gip Winecoff
Posted by Anonymous on Wednesday, August 24, 2005 8:54 PM
Thanks Gip, I'm so not sure of what I'm doing that any information is good, usefull information and yours is actually a great help. Speacially about laying the parts out on tape.
Posted by Anonymous on Wednesday, August 24, 2005 9:07 PM
in complete agreement with styrene, apart from I dissagree with him,lol
As he rightly points out, experiance and falling flat on your face will, over time, teach you the correct way to approach a given set of circumstances.
I for example am building a 1/100th HMS victory, which contains over 2100 parts! 700 of which are for the canons! so yes, I did spray the parts on the sprue, then just cleaned them up after.
horses for courses my friend, there's no right or wrong way, just the way that works for you!
Posted by Anonymous on Wednesday, August 24, 2005 11:24 PM
I too think that you never paint parts on a sprue. Cut them off, clean them up and then put them on a piece of rolled over masking tape that has been attached to a piece of cardboard. Paint that side and when dry put them opposite side down on a new piece of tape and paint the other side. Beer cases are a great source of cardboard and courage.
