How to scribe something more putty than plastic?
    April 2005
Posted by wing_nut on Tuesday, September 6, 2005 8:48 PM
Instead of buying the AM TA 152 tail to convert my JV-44 190D-9 I figured I would try modifying the tail of hr kit. The only really difference is the angle of the leading edge… about 7 degrees more vertical.
So my question is this: With the basic structure being plastic there will be a lot of putty to fill in and build up. How well does Tamiya putty scribe? I will have some panel lines to put back and the bulk of it will be in thick(ish) putty instead of plastic. Any special treatment or considerations? Or do I just scribe away like always?
Marc
Posted by Anonymous on Wednesday, September 7, 2005 2:33 PM
Tamiya putty and most other putties don't scribe well at all. I would recommend buying the AM Ta 152 tail. I think there were more differences than the tail. The whole plane was longer(nose and tail) with a different engine.
    February 2004
Posted by tlivancso on Wednesday, September 7, 2005 8:53 PM
Could you rebuild the tail using styrene and CA. Harden CA will scribe better than putty but takes a bit of effort.
Cheers,
Thom
IPMS Member #42958 /  AMPS Member #2091
IPMS Central Connecticut (President)
IPMS Northeast Military Modelers Association (Web Master)
Like Alice "I try to believe in three impossible things before breakfast"
    September 2004
Posted by Borg R3-MC0 on Thursday, September 8, 2005 4:53 AM
Try using a two component epoxy putty like Milliput. This will dry rock hard (when properly mixed) and can be scribed.
    April 2004
Posted by crockett on Thursday, September 8, 2005 6:44 AM
I wouldn't try to structurally construct anything with putty. Styrene is a suitable material, but the Ta 152 vertical stabilizer is something that I would not take on. Mow a few lawns, and get the money for the AM tail.
Steve
    April 2005
Posted by wing_nut on Thursday, September 8, 2005 7:52 AM
Thanks for the ideas. Ryan, you are right… it does not scribe well. A test patch showed due to relative softness it is hard top not gouge a line instead of scribe. I am building Yellow 6, which is said to have been on the assembly line with a small group of aircraft that had the larger wood tail as the only modification so the rest of the airframe should be OK as is.
http://hem.passagen.se/galland/kg27.html
The supporting structure is a styrene spine with styrene strips filling and sanded to a basic shape, with coats of Tamiya putty and looks good so far.
Thom, I you are right about CA so I will try “painting” the putty with CA to see if it will harden the surface enough for a better scribe line.
Marc
