how to make stubborn decals settle
Posted by Anonymous on Thursday, September 8, 2005 2:34 AM
its really dissapointing whenever i buy kit from this particular manufacturer whenever i come down to the decal placement. i just really find it hard to just let it stay. i dont know if im the only one having trouble with it. any suggestions on how to get it right? it always gets to the part that it would peel off and crack after a couple of days.whats the best thing to do?
    September 2004
Posted by Borg R3-MC0 on Thursday, September 8, 2005 4:44 AM
This is my decal sequence
1) glosscoat, a smooth surface prevents silvering
2) put decals on, I use vinegar/sol/set to soften the decals
3) with really stuborn decals, use future a setting solution
Then finish the model (gloss coat, wash flat coat) as wanted.
You are not the only one having problems with decals, for more idea's look in the "decal"section of the forum.
Posted by mass tactical on Friday, September 9, 2005 4:00 PM
Ditto the use of Future. Place a small dab on the place where the decal goes and then apply a little on top. As the Future drys, it will cause the decal to pull down on the surface. Use a very light coat of Future.
Mike M
Posted by Swanny on Friday, September 9, 2005 6:05 PM
Sounds like a Tamiya kit. I seal the model with Future first then apply the decal with a drop of Micro-Set followed by an application of Micro-Sol and if that does not do the trick then I'll apply some Gunze Mr Marker Soft. Of course if possible I will replace the decals with an aftermarket set and just step around the problem.
Posted by Anonymous on Saturday, September 10, 2005 2:08 AM
pag dito saten pre punta ka lang sa Lil's Futaba megamall or makati.hanap ka ng setting solution for decals kamo. Mr.Hobby setting solution ang meron sila. pag sa Harrison plaza naman meron sila nung Micro Set and Micro Sol. un ung alam ng mga taga forum =)
    September 2004
Posted by Borg R3-MC0 on Monday, September 12, 2005 2:52 AM
eeehhh, luis, I understand that it's phillipino, but I still would like to know what you typed, maybe it's a good tip that I can use.
Posted by Anonymous on Monday, September 12, 2005 9:46 AM
Realize, too, that some decals just stink! And as Swanny said; check out aftermarket. It's worth the wait and money as you usually have lots of time devoted to the project by now.
