Resin Prep
    June 2005
Resin Prep
Posted by Pukindog on Tuesday, September 13, 2005 8:12 PM
Hi everyoneThumbs Up [tup]
Can anyone give a resin newbie a guiding hand? I need input on the best and safest way to remove the big pour gates on the bottom of my ejection seat. i have never worked with resin before and need someone I can contact for help that is very patient. If anyone is interested in giving me a much needed hand, please let me hear from you!!Dead [xx(]
Thank you to all,
Evolution
Posted by Anonymous on Tuesday, September 13, 2005 8:31 PM
A razor saw is the best tool for removing pieces from their casting blocks. Micro Mark sell x-acto blades with teeth that also are great to use.
I recommend to clean resin with denaturated alcohol before painting. The denaturated alcohol will remove the grease, oils, and mold release agents from the resin. Resin can be glued using CA, Testors cement for wood and metal, and epoxies. Cleaning resin should be done with a x-acto knife and wet sanding while wearing a mask. Resin dust is toxic.
    December 2004
Posted by Hippy-Ed on Wednesday, September 14, 2005 7:52 AM
The razor saw is one of my best investments! I too am new to resin AM stuff. Just remember, Don't rush thru it!! This stuff is very brittle.
If you lose your sense of humor, you've lost everything
Posted by Swanny on Wednesday, September 14, 2005 10:25 AM
My most commonly used tools are the razor saw, fresh Xacto blades, Dremel cut-off wheels and sanding drums (use a dust mask) and sheets of metal grade sandpaper. Feel free to contact me off-board for more help if you need it -- my email is on my website.
