Bare Metal Foil help
    February 2004
Posted by RichardI on Saturday, September 17, 2005 10:27 AM
Are any of you folks out there using this for 1/48 scale aircraft? I have some and have applied it to some of the less complicated parts, but I can't figure out how to use it on compound curves, like wing edges, horizontal stabilizers, etc. It looks really great where I've used it so far.
Any advice on more advanced techniques for applying it? The only articles I've seen don't cover compound, tight curves.
Thanks,
Rich Cool [8D]
On the bench: 1/48 Revell PBY Catalina 0A-10A. Next up: Moebius 1/24 Chariot from Lost in Space.
Posted by Anonymous on Saturday, September 17, 2005 5:36 PM
I recommend tos use Alcad or SnJ. They are much easier to apply and will look just as good if not better.
    February 2004
Posted by RichardI on Sunday, September 18, 2005 3:33 PM
Not many responses, so I found this:
http://ww2fighters.org/forums/index.php?showtopic=2270&view=findpost&p=14279
Looks interesting...
Rich Cool [8D]
Posted by Anonymous on Tuesday, September 20, 2005 2:54 PM
interestingBig Smile [:D]
    January 2003
Posted by gbritnell on Tuesday, September 20, 2005 3:54 PM
Hi Rich,
I did a Monogram "Texan" with it but don't have any pics. I didn't have any trouble applying the foil except in the tightest curves and there I just overlayed a little and then burnished it. Unless you get your face right against it you can't tell. I used the regular chrome not the extra shiny. I have some pics of a 1/72 Sabre that I did so I'm including them.
gbritnell
    February 2004
Posted by RichardI on Tuesday, September 20, 2005 4:46 PM
Hey thanks gbritnell! A question if I may Big Smile [:D]. Where is the best place to put the seams? Should they be on the panel lines, or away from the panel lines?
Should I put it on in as large a pieces as possible, or is small ok? Ok, I know that's more than one question, but those pics look great!
Thanks,
Rich Cool [8D]
    January 2003
Posted by gbritnell on Tuesday, September 20, 2005 6:10 PM
Hi Rich,
I try to lay on as large a piece as possible to start, with some forethought on where a curve will get too complex to stretch the foil. I then trim the foil to the existing panel lines. You will find that BMF will stretch quite a bit to follow some fairly tight curves. Just coax it and rub it out as you go. The hardest area I've had to do is on the nose of a wing tank. The best thing to do is lay it on in strips and let them overlap a little at the nose. Once you burnish and buff them they become almost invisible. If you have an extra tank or bomb in your spares box practice on it. It goes quite well after you get the hang of it. Good luck.
gbritnell
Posted by Anonymous on Wednesday, September 21, 2005 4:00 PM
When using foil...
How long do you have to burnish and smooth the foil before the adhesive is too grippy?
do you handel recessed panel lines?
- jamey
    June 2005
Posted by Powder Monkey on Friday, September 23, 2005 11:24 AM
This site has a lot of stuff about BMF. Its a model car site, but the same rules apply. Search the knowledge base .
http://www.briansmodelcars.com/mb/index.asp
    October 2004
Posted by shroomy on Sunday, September 25, 2005 2:31 AM
what a font of knowledge all you guys are
    March 2005
Posted by blackcat on Sunday, September 25, 2005 8:09 AM
very interesting
