Exhaust staining on aircraft.
Posted by R Bolton on Monday, September 26, 2005 9:54 PM
Hi,
Since I am color blind it is hard for me to see what colors of paint to use to represent exhaust staining on WWII aircraft, such as F6F hellcat night fighter, TBM, P-47, P-51, FW 190. I think the color of the aircraft determines what colors I would use for the exhaust stains, but since I can't see the colors I was wondering what colors other people use.
    September 2004
Posted by Borg R3-MC0 on Tuesday, September 27, 2005 3:07 AM
On dark colored aircraft the light stains are more visible (grey, light brown and even white)
On light colored aircraft dark staines are more visible (black and dark brown.)
Posted by Anonymous on Friday, September 30, 2005 4:40 AM
i like to use a tamiya paint called "smoke". it's a translucent sort of gray. excellent for exhaust marks!Cool [8D]
Posted by Swanny on Friday, September 30, 2005 6:40 AM
I've used Tamiya X-19 Smoke as a base for some time for exhaust staining followed by some gray, black or brown ground pastel chalk. Recently I picked up some eyeliner swabs from the make-up department of the local drug store and have been using them to apply the chalks without using the X-19 Smoke. The results have been pretty good, just make sure this is the absolute last step in finishing the model done AFTER your dull coat.
    May 2003
Posted by qmiester on Saturday, October 1, 2005 10:55 AM
The exhaust stains colors will vary from aircraft to aircraft as they are a result of the combustion of the mixture (fuel to air ratio in the cylinder). A black stain indicates a very rich mixture whle a near white stain indicates a very lean (and hot) mixture. Ideally, if the engine is well maintained, the stain will be a light gray (slightly lean mixture) with a few streaks of black near the exhaust opening (that comes during shut down)
Quincy
