Airbrushing Vallejo Model Color
    October 2011
Posted by modeler_zack on Friday, May 30, 2014 1:43 PM
Good afternoon all, I am looking for some advice with airbrushing Model Color paints. I am aware that this is formulated for brush painting, but I have herd success stories with airbrushing this stuff, but my first attempt is not a success. I am comfortable using Tamiya paint, but their major flaw is their limited color selection. I have heard many people rave on about AV, So i wanted to give it a try. The Hobby Lobby by me only had one set of Model air, their olive drab kit.  I did not need any colors in it, so I picked up the model color I needed. As my test, I went to my trusty spoon primed with Tamiya primer. The paint was mixed 50/50 with bottled water and it beaded right up. Went back to Hobby Lobby to see if they had the airbrush cleaner that people had good sucess using along with distilled water, but they didnt have any. The only airbrush cleaner they had was from createx. Same story.
Any ideas? My only other guess is the paint wasnt mixed up enough. Oh, before I forget, I was shooting at 10-15 PSI. I really want this to work. I have my hopes up pretty high.
    December 2011
Posted by Chrisk-k on Friday, May 30, 2014 6:55 PM
I've given up on airbrushing Vallejo Model Air paints.  Once they start to dry, only lacquer thinner can remove them.  Vallejo AB cleaner doesn't remove dried Vallejo paints.  They do dry quickly.
When I airbrushed Vallejo stuff, I added Flow-Aid and a retarder to prevent clogging.  Even so, Vallejo clogged my AB in a few minutes.  I know some people get great results from airbrushing Vallejo, but it was not for me.  I never have a problem with spraying Tamiya.  Sure, their color selection is limited, but with a free app like imodelkit, I have no problem reproducing a variety of colors with Tamiya.
I do use Vallejo for brush painting, though.
Iwata HP-CS | Iwata HP-CR | Iwata HP-M2 | H&S Evolution | Iwata Smart Jet + Sparmax Tank
    October 2011
Posted by modeler_zack on Friday, May 30, 2014 7:58 PM
Huh, that's the first acrylic I have heard of needing lacquer to strip it when dry. I'm use to taking windex to Tamiya and it just melts off. Thanks for the heads up, and the app. I was not aware of it.
With my Limited airbrushing experience, I find it hard to botch up Tamiya.
    May 2012
Posted by pilotjohn on Friday, May 30, 2014 10:10 PM
Hi;
Both Chrisk-k and I have talked about this one earlier, and I am one of the ones who has no problem airbrushing either Model Color or Model Air.  I am no chemist or scientist, but my understanding is that since Model Color is not put in the bottle airbrush ready, you will need to thin it as you talked about.  I even thin Model Air.  Basically the Model Color is too thick at 10 PSI even at 50/50.  You need to have the consistency of 2% milk for pretty much "normal" spraying.  At 10 PSI you will almost need water viscosity.
I have been experimenting at lot with them and I find a mix of 2 to 3 drops of Flo-Aid, one drop of retarder and then about a 70/30 to 80/20 mix for Model Air and at least a 50/50 mix for Model Color seems to work.  I spray at 18 PSI.  You can get pretty close in with a double-action ab at 18 PSI.
I have seen folks post who have said you can't do mottling, etc. with Vallejo and I don't agree at all.  It just takes lots of practice and understanding the acrylics.  If you can compare the Model Air against the Model Color side-by-side you will see the huge difference.  Take the Model Color you have and compare it to the Tamiya on a palette and you will see the same thing.  I would suggest getting a flat piece of styrene (or and old model), and then trying different mixes until you get one that works.  I am in Arizona and we have humidity routinely less the 20%, so things will dry much faster when I am spraying than in a more humid climate.
I also use Model Master acryls and they work very well for me also.  I just like Vallejo's bottles better which waste less paint and don't require all the lid cleaning like Model Master does.  As Chris said, Vallejo brush paint just beautifully.  Again, I love acrylics and won't touch enamels and there are many who are vice-versa.  There is no wrong paint IMO.
Hope that helped.
John
    May 2013
Posted by Greg on Friday, May 30, 2014 10:50 PM
I agree with John. I'm no master at airbrushing Vallejo Model air, but I use it for the same reason you got yours, Zach. Color availability.
I also spray at 18 PSI. I have read in a few places that Vallejo is best airbrushed at that PSI or even as high as 21. I use Vallejo's own thinner, but know folks do just fine with other thinners, distilled water included. As you already found out, the Model Color is really viscous (if I spelled that right, I mean thick), and it takes some messing around to get the thinning ratios right.
2 cents from a relative Vallejo  rookie, anyway.
    March 2005
Posted by TarnShip on Friday, May 30, 2014 11:18 PM
I had to keep about 2 dozen Model Color/Model Air/Etc paints to have the colors I need.
So, I went in search of the best thinner I could find.
I have a bottle of this  redfroghobbies.com/productDetail.php  , I got it in a LifeColor order from Red Frog.
I like just opening a bottle and painting away,,,and this AK thinner works for that.
You do have to change the thinner to paint ratio a bit depending on whether it is for Model Air, Model Color, Panzer Aces, Italeri, Color of Eagles, etc, etc,,,,,,but, it does work as long as you are flexible with how low you take your air pressure.
I am not going to give up my Flow-Aid and Slow-Dry just yet, but, this AK beats any other thinner I have tried for the "Vallejo Group" of paints. (disclaimer, I have not tried it with LifeColor yet, because I still have plenty of their thinner and it works just fine, so I am not ready to experiment just yet)
Rex
almost gone
    July 2013
Posted by modelmaker66 on Saturday, May 31, 2014 12:10 AM
I use Tamiya and Vallejo. Like has been said, Thinning is important, and I use the Vallejo acrylic airbrush thinner and have had great results. Thinning ratios and air pressures need to be figured out by you for you particular airbrush, compressor, climate, comfort level. Take a day and practice on some sheet styrene. Vary the pressure and thinning and keep a record of what works best and use that as a base point in the future. Have fun!
    October 2011
Posted by modeler_zack on Saturday, May 31, 2014 11:34 AM
Last night I went out and picked up a dropper bottle of their paint thinner, the milky colored stuff and I will order a bottle of airbrush thinner. For sure I will use the stuff for brush painting and tamiya for airbrushing. I'll keep experimenting with airbrushing villejo until I got it down. My goal is to keep it all acrylic as I did a test spray with enamel, mind you with a proper vented spray booth and respirator, I didn't like it one bit. The room still stunk and the wife didn't like it, not to mention I don't like cleaning the ab with oils. I am strictly acrylic now.
    October 2011
Posted by modeler_zack on Sunday, June 1, 2014 9:01 PM
I had great success using their thinner medium number 70.524. Pick was using roughly a  2:3 ratio. I could of thinned  flat red a bit more then I did neutral grey.  I guess you guys weren't kidding about tip dry    Soon I'll  have an order for model air and  model color with the proper airbrush thinner. Sofar with my first expierence, I am thrilled.
    October 2011
Posted by modeler_zack on Monday, June 2, 2014 10:01 PM
I want to put in an order for paint, but before I do, I would like some opinions on common colors that should be added. What shade of green should be used for radar screens, and what would be a good vallejo color for light gray fs# 33613?
This is my current list.
MODEL COLOR
COLOR VALLEJO NUMBER M.C. NUMBER FS NUMBER RAL NUMBER RLM NUMBER
US FIELD DRAB 70.873 142 30118 - -
BLACK 70.950 169 37038 - -
FLAT RED 70.957 031 31136 - -
US DARK GREEN 70.893 095 34079 - -
BLACK GREY 70.862 168 37031 - -
IRAQUI SAND 70.819 124 30475 - -
FLAT YELLOW 70.953 015 33655 - -
FOUNDATION WHITE 70.919 002 - - -
NEUTRAL GREY 70.992 160 36173 - -
SILVER 70.997 171 17178 - -
GUNMETAL GREY 70.863 179 37200 9007 3
NATURAL STEEL 70.864 178 - 9006 -
The additional colors needed that Hobby Lobby does not carry are:
NEEDED COLORS
COLOR
VALLEJO NUMBER PAINT LINE FS NUMBER
PALE BLUE 70.907 MODEL COLOR 36473
GRAY PRIMER 71.097 MODEL AIR 36231
INTERIOR GREEN 71.010 MODEL AIR 34151
FRENCH TANK CREW 70.320 PANCER ACES 14255
BARLEY GREY 71.051 MODEL AIR 36440
LIGHT GRAY ? ? 36373
RANDOME TAN 71.074 MODEL AIR
33613
    July 2013
Posted by modelmaker66 on Monday, June 2, 2014 11:10 PM
Vallejo 074 is the correct color match. Hope it helps.
    October 2011
Posted by modeler_zack on Tuesday, June 3, 2014 6:27 AM
I assume your are referencing  intermediate green 70-891 for the radar screen?
