What the HECK is wrong with my Testors paint?
    May 2014
Posted by SubarooMike on Sunday, July 13, 2014 8:40 PM
Hello everyoneBig Smile
I am trying to spray Testors Flat Aluminum and it will not spray for HECK.  The spray is extremely intermittent.  For example:   Air, air, air, air, puff of paint, air, air, air, air, air, air, puff of paint. etc.   I tried spraying water with food coloring and it spray that beautiful with NO problem.      I am NOT under-thinning the paint because I have already tried over-thinning it.  No matter how thin, the Testors Alum will. not. spray.   I am thinning the Testors with mineral spirits.  Is,generally speaking, Testors just sh*t?  Any help would be greatly appreciated!
 -- Michael
    July 2004
Posted by stikpusher on Sunday, July 13, 2014 8:59 PM
Is this Testors Model Master Enamel? Acrylic? The square bottle stuff? If enamel, I highly recommend their universal enamel airbrush thinner- great stuff. What is your ratio of thinner to paint, your approximate psi, and airbrush type? Usually I have no problems with their enamels, but their acrylics can be finicky.
U is for URANIUM... BOMBS!
N is for NO SURVIVORS...
       - Plankton
LSM
    January 2013
Posted by BlackSheepTwoOneFour on Sunday, July 13, 2014 8:59 PM
Testors do have special metallic paints for airbrushing as opposed to using enamel metallic colors. I'm suspecting the metallic flakes in enamel paints are giving you trouble. Perhaps someone will chime in for advice.
    May 2014
Posted by SubarooMike on Sunday, July 13, 2014 9:09 PM
I honestly can't believe I forgot to provide that info! sorry!
-Enamel  old-style square bottle
- Badger 105
-15-20 PSI  (my normal for non detailing)
-50/50, 40/60, 30/70  (%thinner presented by second number)
Blacksheep214-  I have tried their metalizers, but I did not like their look once sealed.  I am kind of thinking exactly what you are
I'm probably just going to cut my loses and buy some Alclad
    January 2005
Posted by Watchmann on Sunday, July 13, 2014 9:13 PM
I've not used Testor's enamel paints in a long while.  If I remember, aren't there a lot of "metallic" particles floating in the paint?  I recall the aluminum and steel being rather lumpy.  If it's still the same, that could be a problem.
It could also be the mineral spirits; it's possible it's turning to gum.  Have you tried to brush the paint after you mix it as a test?  Have you tried Testor's airbrush thinner?
    July 2004
Posted by stikpusher on Sunday, July 13, 2014 9:19 PM
Just a rough guess tells me it is a clogging issue, from the sound of it. Do you shake or stir your paint? I have found that shaking is not too good for mixing paint. But a good thorough stirring does the job every time. Same with mixing with thinner prior to airbrushing. Is it an older or newer bottle of paint. Older bottles tend to get thicker with age. But conversely I have been having problems with newer bottles not lasting very long in the jar. I do not know if their formulation has changed due to some law, or if it is simple quality control problem. Have you cleaned your airbrush afterwards and found it clogged with pigment build up?
       - Plankton
LSM
    May 2014
Posted by SubarooMike on Sunday, July 13, 2014 9:47 PM
Oh yes, there is a lot of metallic in the paint. I have not tried to brush the mixed paint. I also have not tried their airbrush thinner. I would buy some, but I think i'm just going to go with a different brand
    May 2014
I shake and stir the paint. I do both every time.  Normally I have a few BB's at the bottom of the jar too -- but not this time.   It's a brand new bottle, but I have no idea how long it was at the store.  It did look a tad separated when I bought it, but it mixed back together well.   I did not notice any pigment buildup.  When i ran the mineral spirits through it into the cleaning pot, it cleared it out perfectly.
    May 2014
Posted by SubarooMike on Sunday, July 13, 2014 9:48 PM
By the way, how do I quote/reply  certain people in the thread?  This forum is a lot different then others I am on
    August 2005
Posted by Phil_H on Monday, July 14, 2014 1:01 AM
At a guess, I'd suspect that it's a problem with the metallic particles settling and clogging the airbrush. I often have a similar problem with Tamiya metallic acrylics.
You get a little burst of paint when you pull back on the trigger and it stops. Allow the trigger to close and you get a little "splat" of metallic particles. Pull back and you get an irregular burst and it stops again.
Over-thinning often exacerbates this problem as it allows the particles to settle even quicker. If you have a bottom-feed airbrush, you can swish the paint around in the jar between passes to keep the metallic pigments suspended, but it's difficult to do so with a top-feed.
cml
    March 2007
Posted by cml on Monday, July 14, 2014 7:36 AM
I'm with the others - i suspect clogging.
Just a thought, are you using a fine tip on your a/b?  I use a Badger 100LG with medium tip. It will a/b metallics pretty well, but, unlike with most other paints, it will clog up and i have to blast out the clump and continue.
A fine tip might be inhibiting flow a bit.
Chris
Posted by Don Stauffer on Tuesday, July 15, 2014 9:28 AM
I airbrush Testors flat aluminum enamel frequently, never had a problem.  No, it is not a bad paint.  It is one of the few really flat aluminums available.  I do thin any aluminum (or any metallic) paint a bit thinner than non-metallic paints, but not by that much.
    June 2013
Posted by Reaper420 on Wednesday, July 23, 2014 3:34 PM
I tend to stay away from the Testors in the square jars. I dont know just reminds me of back in the day when models and supplies were not that great. I always use Model Master enamel and acrylics. It is very good paint. Metallic acrylics AB a little better than Metallic enamels, but you still have the problem of the metal flakes. It wont really matter if you switch brands, you will still have the same problem because of the flakes. What you need to do is switch to a larger tip on your AB. That will help reduce clogging issues. Also try to keep the flakes suspended while painting. If they settle, your going to get clogs. Alclad is great to use for metallic finishes, but it still has flakes, so you will most likely run into the same problem.
Kick the tires and light the fires!
    January 2013
Posted by BlackSheepTwoOneFour on Thursday, July 24, 2014 8:07 AM
Ditto on Testors square paint bottles. I still have a few colors but very rarely I use them.
Posted by Texgunner on Thursday, July 24, 2014 8:54 AM
I've found the Testors paint in the square bottles to be excellent product.  It sprays well and is great to brush too.  Heh heh, I still have a few bottles that are 25 years old or more, and it's still viable paint.  Sometimes, just the right color is available in those little bottles.  Ymmv...Smile
Gary
"All you mugs need to get busy building, and post pics!"
Posted by Don Stauffer on Thursday, July 24, 2014 9:01 AM
I also use a lot of the square bottle stuff. I thin it to same dilution as the MM stuff, can't tell the difference as far as airbrushing goes.
