moisture problem
moisture problem
Posted by urich on Sunday, July 20, 2014 5:23 PM
Hi all I'm looking for help with airbrushing I'm using a Iwata Neo airbrush with a moisture trap at the brush with a Sparmax air compressor in a out door shed with a out side humidity of 85% every once in a while I will get a shot of water mixed with the paint. well you know how that turns out. With out telling me to AC the shop how can I stop this Thanks J
Posted by urich on Sunday, July 20, 2014 9:47 PM
Sorry I just read were I put this in the wrong form Please remove
cml
    March 2007
Posted by cml on Sunday, July 20, 2014 10:42 PM
Hi Urich,
Not sure how you can 100% fix the problem, however, i'd suggest adding a moisture trap at the compressor too.
I use Sparmax's most basic compressor (the little gold one). It doesn't have an auto shut off, which means it runs constantly. I use three moisture traps - at the compressor, at a joint between two air hoses and then one attached to the airbrush.
If i use it long enough (say, over 40 mins) i'll still get moisture. Only thing is to turn it off, drain the traps and come back later when the compressor has cooled a bit.
In short, maybe adding an extra one or two traps will help limit the problem?
Chris
Posted by urich on Monday, July 21, 2014 4:04 PM
Thanks Chris, Can you give a part number for the traps you use or a source? It sounds line we are running the same compressor I got mine at the Hobby Lobby Little orange to gold color and you said inline? I have one at the brush but that is the only place
cml
    March 2007
Posted by cml on Monday, July 21, 2014 6:26 PM
Hi Urich,
Sorry, can't give a parts no., but can try and provide links so you get a visual.  Just remember, these are all Australian websites, as that's where i live, but the parts should look similar around the world.
Also, if you don't have a moisture trap on the compressor, i assume that means you don't have a regulator either? Mine came with both (albeit, a poor regulator).
Finally, you'll just need to do a bit of a look to see what size fittings are on the compressor, you may need to buy some adapters to make everything fit.
Moisture trap and regulator: www.hobbytools.com.au/filter-regulator-with-moisture-trap-and-gauge
I'd put this on the compressor. Again, just need to check the connections.
From there i run a long air hose from a hardware store to this sort of moisture trap: www.bunnings.com.au/project-air-in-line-moisture-tap-_p6273009
I then attach the braided airbrush hose directly to this moisture trap.
Keep in mind, you don't have to use the middle trap - and in fact, to do so, you will have to toy around with a number of different parts such as these (www.bunnings.com.au/spear-jackson-project-air-charge-air-syle-fittings-6-piece-set_p6270155) to make everything fit.
I hope this helps. Let me know if you have any other questions.
Chris
    January 2005
Posted by Watchmann on Friday, July 25, 2014 1:03 PM
You might try keeping the piston cover cool by using a fan.  They get hot, and moist air passing through the hot cover causes the moisture to condense.  I used to airbrush outside too, and I always had the same trouble.
Posted by Texgunner on Friday, July 25, 2014 1:17 PM
I'm sorry to read of your trouble.  I can only offer a two word answer though.  Carbon dioxide.Smile
Good luck, Gary.
"All you mugs need to get busy building, and post pics!"
