Question about Decanting
    December 2011
Posted by Chrisk-k on Tuesday, September 16, 2014 7:49 PM
I want to decant a Tamiya TS rattle can.  I just watched the how-to-decant video by Aaron Skinner.  Because the decanted paint still has the propellant in it, he advised to leave the jar open for a while.
My question is, "How long should I leave the jar open to let the propellant to boil out?"  The TS is a lacquer paint, so I'm worried if the jar is left open for a while, the decanted paint will easily start to dry.
Iwata HP-CS | Iwata HP-CR | Iwata HP-M2 | H&S Evolution | Iwata Smart Jet + Sparmax Tank
Posted by Wingman_kz on Tuesday, September 16, 2014 9:56 PM
You can speed the process by gently stirring occasionally. I usually set the lid on the jar and let it set overnite. I haven't decanted that particular paint but have done this with a lot of other lacquers and haven't had a problem. I know some folks have used decanted paint within hours or even minutes and say they've had no problems. I've had it literally foam up in the airbrush if I tried to use it too soon so overnite is the rule for me.
Tony
    April 2005
Posted by wing_nut on Wednesday, September 17, 2014 3:19 PM
I decant Tamiya, and everything else, directly into bottles like tis.  If you want to leave sit overnight it allows the gas out and minimizes evaporation since it is already at the right consistency.  The process can be sped up easily by closet the spout , shaking and resealing the pressure.  Do that  few times' til it goes flat.  Like getting the fizz out of a bottle of soda.
 I order these about a couple of hundred at a time either 1 or 1.5 oz.. That last a loooong time too.  The other thing they are great from is when you have a project that will need a large amount of paint.  This way you can get the consistency, and color if you are mixing,  you need for a bath big enough to do the whole job and not worry about mixing a 2nd batch tat might be different.
Marc
    April 2009
Posted by Cadet Chuck on Thursday, September 18, 2014 3:28 PM
I always thought they put the paint in a spray can for a good reason.  If it's in a can, I spray from the can!  Why decant?  If I were too ham-handed to spray lightly from a can, I wouldn't buy them!
    December 2011
Posted by Chrisk-k on Thursday, September 18, 2014 7:58 PM
A good reason is to allow folks without airbrushes to paint.  I personally see no advantage to use a spray can over an airbrush.  I have yet to find a rattle can that works as good as my Iwata Eclipse or HP-B Plus.
    January 2014
Posted by jelliott523 on Monday, September 22, 2014 8:36 AM
Before I acquired my first airbrush, I often used a rattle can to spray with.  At the time, I thought I was getting a pretty decent looking model.  However, now that I have the airbrush, there is a HUGE improvement in how my models turn out.  First, the paint can be applied thinner and more accurately.  Second, I often got a pebbly looking finish when spraying flat enamels.  There are many airbrushes out there that wont break the bank and you can even find cheap combo kits that have the airbrush and compressor included.  Granted the compressors are not usually the best bet, but if you want to start down the path of airbrushing, I've found its not a bad way to go.
    February 2007
Posted by mitsdude on Monday, September 22, 2014 11:04 PM
You also get more control with an airbrush. As in spraying fine lines, dots, circles or camo without having to tape. An airbrush can be adjusted to put out very little or a lot of paint. These things are next to impossible with a spray can.
    April 2009
Posted by Cadet Chuck on Monday, September 22, 2014 11:11 PM
Yes, that is all true.   I usually use the spray cans for a basic primer coat, where fine control is not important.  Quick and dirty!
"Get 'er done!"
    January 2012
Posted by Misty on Tuesday, September 23, 2014 2:32 AM
same here, but it wastes a lot of paint if you are priming small parts, so i decant too.
