Cambpell Hausfeld air compressor problems
    October 2009
Posted by greentracker98 on Thursday, October 23, 2014 5:00 PM
I'm still having air compressor problems. My Campbell Hausfeld won't pump up. They sent me a check valve, but it didn't work.Anybody have any ideas as to what may be wrong?
THanks
A.K.A. Ken                Making Modeling Great Again
Posted by Texgunner on Thursday, October 23, 2014 7:47 PM
I assume that you have a tank attached?  Is there a drain/petcock on the bottom of the tank that might be open?
"All you mugs need to get busy building, and post pics!"
    October 2009
Posted by greentracker98 on Friday, October 24, 2014 12:35 AM
Texgunner
It was factory made with tank, its a small hotdog  (2 gallon)
Your post has me thinking Tex. If I find that that drain is open, I'll hide for the next year and a half. It could be that i am opening it rather than closing it. I'll let you know tomorrow when I can run it. That thing will wake the dead its so loud
    October 2007
Posted by Milairjunkie on Friday, October 24, 2014 8:10 AM
If the non-return is working, the tank is closed & there are no other leaks I would suspect a failed valve in the head.
    October 2009
Posted by greentracker98 on Tuesday, October 28, 2014 9:29 AM
Hmmmm, Guess I'll have to check it out
Thanks
    October 2009
Posted by greentracker98 on Sunday, November 2, 2014 6:07 PM
I tore the compressor down the other night. I couldn't see anything that was bad. So, I guess i'm in the market for a new compressor. The only problem is the gas company, the electric company and Verizon are all standing there with thier hands out. Thats life I guess
Anyway, I'm going to get all my bills caught up then I'll get the Little Dewalt I've got my eye on . Does anyone have this? Whts it like for airbrushing?Onre review says its quiet, light weight and would be great for airbrushing.  Any thoughts/opinions?
www.homedepot.com/.../202019874
    November 2008
Posted by plasticjunkie on Sunday, November 2, 2014 7:04 PM
Did you check out the check valve?
 GIFMaker.org_jy_Ayj_O
    October 2009
Posted by greentracker98 on Tuesday, November 4, 2014 9:24 PM
plasticjunkie
CH sent me a new check valve. Didn't make any difference
when i opened the compressor up. the cylinder - pistom - and head was dismantled. Every thing was loose. I thought I found the problem, but I'm guessing being run with everything loose.like that  it really messed things up.
    November 2008
Posted by plasticjunkie on Wednesday, November 5, 2014 6:42 AM
Hopefully it may work if you are able to re assemble the loose parts.
