working with white paint.
    March 2013
Posted by tetraodon on Wednesday, November 12, 2014 8:37 PM
ive worked with white paint for a while but allways have had trouble, most common trouble has been the paint running no matter what i do. its accross the board, all types and brands, any tips or brands that work?
    July 2004
Posted by stikpusher on Thursday, November 13, 2014 12:06 AM
I get best results with white (using any brand of paint) by doing several layers. First up a rough layer of flat white as a primer to give all the next layers something to bight on to. Then I will do another layer or two or three of satin, semi gloss or gloss white, depending upon how intense I want the white to be.
U is for URANIUM... BOMBS!
N is for NO SURVIVORS...
       - Plankton
LSM
Posted by Don Stauffer on Thursday, November 13, 2014 9:34 AM
There are flat white primers available.  Krylon makes a good one in spray cans.  I almost always use a white primer for both white and yellow paint.  I find primer even more critical for gloss paints than for flats.
    February 2007
Posted by mitsdude on Saturday, November 15, 2014 1:55 AM
Whites and bright yellows are the most difficult for me to work with. When spraying you tend to over do it because it doesn't look like you are getting any coverage. You spray too much and then it begins to run. As mentioned above apply it in several light coats. It certainly doesn't help that these colors, especially enamels, take longer to dry. It may take several days to get a solid coat because of having to wait for the paint to dry between coats.
If you are looking for a really smooth glossy finish I recommend using one of the finer white primers like Tamiya. This stuff is expensive so I save it for when I want that special glossy shine.
    December 2011
Posted by Chrisk-k on Saturday, November 15, 2014 3:46 PM
Tamiya's bottled primers are not expensive at all. A bottle costs $3.80 and is good enough for 15 kits.
Iwata HP-CS | Iwata HP-CR | Iwata HP-M2 | H&S Evolution | Iwata Smart Jet + Sparmax Tank
    January 2014
Posted by Silver on Tuesday, January 20, 2015 11:19 PM
Spray or brush light gray.Then apply the white.allow drying time in between colors.
    January 2015
Posted by Jason21 on Wednesday, January 21, 2015 3:20 PM
I have my favpirite white paint and usually I don't have problems with it.
    August 2012
Posted by JMorgan on Friday, January 23, 2015 2:03 PM
I don't wait for the paint to dry between coats. I spray, wait about 10 minutes and then spray again. Is this good practice?
Posted by Don Stauffer on Saturday, January 24, 2015 10:11 AM
If you don't get runs, it is okay.  You are probably putting on thin coats.
    June 2006
Posted by SoD Stitch on Thursday, January 29, 2015 4:55 PM
If it's less than three (3) hours, that should be fine; otherwise, you'll need to wait at least 48 hours to re-coat, or you'll probably get the dreaded "orange peel" effect.
1/48th Monogram A-37 Dragonfly: 95% (so close!); 1/35th Academy UH-60L: 90%; 1/35th Dragon "Ersatz" M10: 75%; 1/35th DML E-100 Super Heavy Tank: 100%; 1/48 YF-12A, 95%; 1/48 U-2R: 90%; 1/48 B-58 Hustler: 50%; 1/32 F-117, 50%; 1/48 Rafale M: 50%; 1/48 F-105D: 75%; 1/48 SOS A-1H Skyraider: 50%; 1/48th Hobby Boss Su-27: 50%; 1/16th Revell Lamborghini Countach: 75%; 1/12th Otaki Lamborghini Countach: 25%; Tamiya 1/35th M3 Bradley Cavalry Fighting Vehicle: 25%
    January 2014
Posted by Silver on Saturday, February 28, 2015 11:02 PM
After priming use a light gray .Them apply the white.
    January 2014
Posted by Silver on Monday, March 2, 2015 10:17 AM
Drying time is a basic thing to do.If not , you will have run's.It takes years to master the application of a flawless white.
