Anyone mix their own colors?
    May 2004
Posted by cbaltrin on Thursday, December 11, 2014 7:43 AM
I like mixing my own colors some times. However, it gets a little interesting as I am color blind :-) I am just looking on basic advice or "general guidelines". I have mixed gull grey and "chromate yellow" and I am satisfied with those. I have also mixed "Interior green" called for on so many US WW2 Aircraft by just adding more black to my chromate yellow (which is just yellow with a few drops of black). From there I have added more black and they some lt grey to get a dull dk green which "I think" looks like the green sometimes seen in P47 cockpits. But, like I said, I am color blind so I could be completely off base (btw, for those of you who don't know, color blind does not mean you see life in black and white, I just means you don't see colors as well as others and some colors are more troublesome than others...). So I was just wondering if you think my 'formulas' are reasonable? Also, Could someone explain to me what a "bronze green" is and how to mix one? I think it is another interior color. Can't remember where I saw that call out off the top of my head though... Thanks
On the Bench: Too Much
Posted by Don Stauffer on Thursday, December 11, 2014 8:43 AM
One way to quantize colors is to use a photo editing program.  Using the color picker tool you can read the RGB values of any color.  Paint a sample of your mix, let it dry, and scan it with your scanner. Open that image in your scanner, then examine the paint area of the image with the color picker tool.  To speed things up, you can put down several test mixes, scan an image of several blobs of different mix, and look at each blob.  Now the tricky thing is, most colors mix using subtractive colors (magenta, cyan).  So, you need to read up on color theory (lots of good articles online- try google).  I believe some of the better photo editing programs may even convert to yellow-cyan-magenta as an option.
    February 2015
Posted by Bick on Thursday, December 11, 2014 8:50 AM
Hi cbaltrin,
I use craft acrylics for most of my builds so have to mix colors frequently. I find iModelKit (an iPhone app) very useful because it allows you to pick one of the paint mfrs colors and mix other colors to match. I also use the color mixer in PhotoShop if I have a scan of the color I want/need. There are also a couple of color mixing websites (don't have URLs handy but know that Golden Paints has one). And, yes, black and white are toners - they change the hue but not the color. You might find this site useful:
http://scalemodeldb.com/paint
    December 2006
Posted by Fly-n-hi on Thursday, December 11, 2014 8:51 AM
I've mixed several of my own Tamiya paints for colors that I use regularly, like Light Ghost Grey for example.  Often, I use Mr. Color as a guide since their colors are usually very close to the real thing.
    December 2011
Posted by Chrisk-k on Thursday, December 11, 2014 12:08 PM
I mix my own colors using Tamiya acrylics.  I mostly build WWII stuff and my understanding is there was no such thing as a consistent color at that time.  For instance, not every Dunkelgelb paint was the same.  As long as a color looks good to me, I'm happy.
Iwata HP-CS | Iwata HP-CR | Iwata HP-M2 | H&S Evolution | Iwata Smart Jet + Sparmax Tank
    May 2004
Posted by cbaltrin on Friday, December 12, 2014 6:25 PM
Ok, thanks for all the info everyone.
