Tone Down Stark Camo Patterns
    December 2011
Posted by Chrisk-k on Thursday, April 16, 2015 12:55 PM
I've used oil washes to tone down stark German camo patterns.  Washes using MIG and W&N oils work well but I'm getting to dislike the result.  Sure, oil washes are supposed to result in the 'washed out' appearance, but there's something aesthetically unpleasing about it AFAIC.
So for my next build I'm thinking about misting highly thinned Buff or Tan over the 3 color German camo.  I wonder if anyone has used this technique to tone down stark color patterns.
Iwata HP-CS | Iwata HP-CR | Iwata HP-M2 | H&S Evolution | Iwata Smart Jet + Sparmax Tank
    March 2013
Posted by patrick206 on Thursday, April 16, 2015 1:19 PM
I've done that, fairly happy with the results. Also tried mixing in a SLIGHT bit of an appropriate color in the desired clear finish, ( flat or satin,) I liked that even better. A bit of experimenting determined what and how much.
Patrick
Posted by Texgunner on Thursday, April 16, 2015 1:22 PM
Chris, I used that technique to "wash out" the SEA camo on this Monogram F-100D.  I used Floquil Dust if my memory serves me well.
Gary
"All you mugs need to get busy building, and post pics!"
    December 2011
Posted by Chrisk-k on Thursday, April 16, 2015 1:31 PM
I guess because I'm not a big fan of a heavily weathered look, I'm not in love with the result of full oil washes.  I just want a slightly dusty look.  I'll first experiment with a guinea pig model.
The F-100 looks great.  That kind of look is what I'm after.
    March 2014
Posted by BarrettDuke on Thursday, April 16, 2015 5:10 PM
Yes, thinning a lighter color works great. Buff or tan would do the job very well. Think of surfaces that would be more heavily faded and hit those a little harder. Be careful, though. It's easy to get carried away and fade too much.
    May 2012
Posted by pilotjohn on Thursday, April 16, 2015 10:47 PM
You can also add a little of the buff/tan/white/etc. to the color you are spraying.  Makes the color softer.  I also try to be less "hard" on the edges and that takes some of the hardness out of the color also.
John
    June 2012
Posted by Compressorman on Friday, April 17, 2015 8:00 AM
I have done that on a recent aircraft build and was happy with the result.
Posted by Texgunner on Friday, April 17, 2015 8:13 AM
Compressorman
Man, that looks just right!   Very well done, great worn effect there.Bow Down
Gary
    January 2013
Posted by jibber on Friday, April 17, 2015 8:22 AM
Wow not sure whats happening here???
    January 2013
Posted by jibber on Friday, April 17, 2015 8:23 AM
    January 2013
Take my word for it I can't get out of this copy……….Ill work on it
Posted by Don Stauffer on Friday, April 17, 2015 8:42 AM
I do it one of  two ways, depending on the model.  Both ways use my airbrush backed off to a very fine spray.  One is to pick the lightest of the colors and do a very light, translucent overall spray.  The second is to use a white overcoat.  This simulates paint chalking.  For the chalking I use it heavier on top (horizontal) surfaces, less on sides, and none on bottom surfaces.  For the lightest camouflage color I put on the same thin coating over all surfaces, cuts down on contrast.
    November 2014
Posted by BLACKSMITHN on Friday, April 17, 2015 10:20 AM
I use a product called Doctor Ben's Weathered Driftwood weathering solution. It's alcohol based and seems to airbrush just fine, with a light tan color. Depending on how many coats and how heavy you spray, you can make something look slightly dusty or like it just emerged from a sandstorm. If I'm unhappy with the result, a light rub with Iso removes it.
Posted by Texgunner on Friday, April 17, 2015 2:57 PM
jibber, I love the worn paint effects on front!  Very cool...Bow Down
Gary
Posted by Tojo72 on Friday, April 17, 2015 3:13 PM
On 3 color German pattern I will mist it over with Dunkelgelb to pull the whole thing together.
    January 2013
Posted by jibber on Tuesday, April 21, 2015 6:27 PM
Chris I was having trouble with my PhotoBucket but here is a good example pre and post oil wash on this Tiger.
I hope these photos help Chris.
Terry
    December 2011
Posted by Chrisk-k on Tuesday, April 21, 2015 7:38 PM
Jibber,
Your paint job is superb!
