Gloss or flat for streaking?
    August 2012
Posted by JMorgan on Monday, June 29, 2015 4:51 PM
Does it make that big a difference to have a gloss or flat finish when streaking paint down the model?
Posted by Tojo72 on Tuesday, June 30, 2015 12:38 PM
I use a flat finish.
    November 2008
Posted by plasticjunkie on Tuesday, June 30, 2015 1:32 PM
When you say streaking I assume you mean DOT filters where the oil paint dots are dragged down to simulate rain marks and weathering. I use a flat base so that the oils blend better than on a glossy base.
 GIFMaker.org_jy_Ayj_O
Posted by Don Stauffer on Wednesday, July 1, 2015 9:12 AM
Depends on whether you want streaks to look wet or dry.  Glossy streaks look wet, good for oil leaks, water leaks, etc.  For a water leak I sometimes just use gloss clear.  Most rust colors I use are flats, so if I want the rust streak to look wet, as for a spot that often has water coming down, I put the gloss clear over the rust, but not in perfect register.
