dull metallic paint
    August 2015
dull metallic paint
Posted by FlyingPancakeFighterAce on Monday, August 31, 2015 7:06 PM
Hi y'all,
I am a relatively new modeler and have just started to build Eduard's 1/48 avia b.534 series 4. The instructions call for a bare aluminum cockpit. I am trying to find a relatively cheap paint to paint the interior that gives a realistic finish. I have tried several metallic acrylic brands but have had no luck so far. From what I have heard on the Internet that this is to be expected, that metallic acrylic paints are in general total trash. I know that alclad is ideal for any natural metal finish, but I have already spent a lot of money recently on this hobby and would prefer not to have to spend a ton more right now.
So I guess my question boils down to this: are there any not-alclad paint brands out there that can give me a realistic dull aluminum sheen for this cockpit without figuratively annihilating my wallet. I am willing to try pretty much any type of paint*.
*If possible I would also like a brand with several shades of metallic colors so I can vary tones to avoid the monotonous single-shaded cockpit.
let me know if you have any suggestions on what brands I should try.
-Thanks
Posted by Texgunner on Tuesday, September 1, 2015 9:22 AM
I use a couple different paints for that sort of work.  I like Humbrol MetalCote matt aluminum and Testors makes a flat aluminum and a flat steel in their 1/4 oz. square bottles of enamel.   All these are, of course, enamel, solvent-based paint because that's what I use. There are probably acrylic versions that would fill your needs too.
Gary
"All you mugs need to get busy building, and post pics!"
    January 2013
Posted by BlackSheepTwoOneFour on Tuesday, September 1, 2015 12:59 PM
I've used acrylic metallics with no issues whatsoever. Most time, I usually brush it on. I wouldn't say all metallic acrylics are crap but it's a matter of preference.
    July 2004
Posted by stikpusher on Tuesday, September 1, 2015 1:04 PM
For a good dull aluminum shade, I prefer Humbrol 56. It's a nice gray oxidized shade. Humbrol also makes some lighter "Metalcote" shades of aluminum, one buffable, one non, to vary your tones.
U is for URANIUM... BOMBS!
N is for NO SURVIVORS...
       - Plankton
LSM
    December 2011
Posted by Chrisk-k on Tuesday, September 1, 2015 6:12 PM
If you need to paint the entire model with a metallic color, nothing beats Alclad.
If you need to paint only a certain part with a metallic color, MM enamel, Tamiya & Vallejo acrylics are more than adequate.
Yes, this hobby can be expensive!
Iwata HP-CS | Iwata HP-CR | Iwata HP-M2 | H&S Evolution | Iwata Smart Jet + Sparmax Tank
    October 2008
Posted by P mitch on Wednesday, September 2, 2015 3:06 AM
Vallejo have their own metal colours now but I've never used them so cant give an honest review. You could look at polishing pigments there are a couple out there
http://www.uschivdr.com/shopping-categories/shop-colors-paints-pigments-primer/metallic-colors-pigments/
http://ak-interactive.com/v2/?product_cat=true-metal
Both look good, I have the AK and it works fine but would be hard to use for a lot of the detail in a cockpit.
To behonest I love Alclad and while it will cost it will work for what your looking at. If you have an airbrush its the way to go and a bottle isnt that much
Phil
"If anybody ever tells you anything about an aeroplane which is so bloody complicated you can't understand it, take it from me: it's all balls." R J Mitchell
Posted by Don Stauffer on Wednesday, September 2, 2015 9:19 AM
Testors has a flat aluminum in both the little square bottles and the MM line.  I love the stuff- it is my go-to for a flat aluminum finish.  They also have a flat steel in the little bottles that is a bit darker than the aluminum.
    August 2015
Posted by FlyingPancakeFighterAce on Sunday, September 13, 2015 10:35 AM
Thank you all for your helpful suggestions!
I am heading over to my local hobby store to look at those humbrol paints. I figure that I'll wait until I'm building a natural-metal plane to dole out the money for that alclad. In the  meantime I've painted small-detail parts with my alclad metallics, as they look pretty good on stuff like control sicks and whatnot.
