My airbrush has stopped working.
    August 2010
Posted by podcat on Wednesday, September 2, 2015 5:49 PM
I cleaned it out after painting and now it wont paint. What do I do?
    September 2012
Posted by GMorrison on Wednesday, September 2, 2015 5:55 PM
Guessing you can't spray thinner, or alcohol, through it either?
Does air come out?
    August 2010
Posted by podcat on Wednesday, September 2, 2015 5:56 PM
GMorrison
Does air come out?
Yes, but no fluid(s)
    August 2015
Posted by crown r n7 on Wednesday, September 2, 2015 5:56 PM
Do you feel air through the brush when button is pressed
 Nick.
    August 2010
Posted by podcat on Wednesday, September 2, 2015 8:05 PM
Yes, there's a steady rush of air but no paint, thinner is drawn up and sprayed.
Posted by Don Stauffer on Thursday, September 3, 2015 8:22 AM
Did your cleaning just involve running thinner through it, or did you do any disassembly for cleaning?
    January 2013
Posted by BlackSheepTwoOneFour on Thursday, September 3, 2015 10:22 AM
Don Stauffer
My thoughts exactly.
    January 2013
Posted by BlackSheepTwoOneFour on Thursday, September 3, 2015 10:24 AM
Air, but no liquid? Either you ran out of paint or no paint in your paint cup. Hole in the hose or hose not attached to compressor correctly.
    September 2012
Posted by GMorrison on Thursday, September 3, 2015 10:25 AM
In other words, it may be out of adjustment. What type of airbrush is it?
    August 2010
Posted by podcat on Thursday, September 3, 2015 1:28 PM
I,m using a Badger 150 with an Iwata Ninja Jet compressor. Hose is connected as I'm getting a steady strong air supply but it's not drawing paint from the paint receptacle.
    November 2008
Posted by plasticjunkie on Thursday, September 3, 2015 2:35 PM
Here are my thoughts:
Either the paint is not thin enough.
There is dried paint in the body feed tube partially blocking it. Thinner and water will get thru but paint will be a different story.
The air breather hole in the bottle is blocked or pick up tube is blocked.
Not enough air pressure.
 GIFMaker.org_jy_Ayj_O
    January 2013
Posted by BlackSheepTwoOneFour on Thursday, September 3, 2015 2:35 PM
Is it a bottom feed dual action internal mix airbrush? Are you using the glass bottle? If so, is the tube INSIDE the bottle cap still attached to the lid? If not, there's your problem.
    September 2012
Posted by GMorrison on Thursday, September 3, 2015 2:42 PM
All good suggestions. Take the bottle off, but leave the cap and tube on. Can you get any suction at the end of the tube?
Posted by Don Stauffer on Friday, September 4, 2015 9:46 AM
Pure thinner takes very little air pressure in that brush. If it will not spray thinner I would suspect a clog in the line, not lack of air pressure from compressor.  Some of the passages in an airbrush are pretty fine, so they will clog easily if cleaning is not thorough.
    September 2015
Posted by BiodronE31 on Monday, September 7, 2015 8:33 PM
Hey podcat,
Had the same problem with mine yesterday. Remove the needle, make sure it's clean of paint and take a very fine pipe cleaner if you have a cleaning kit of some sort and run it through the back of the disassembled airbrush. Most likely, your problem is a paint clog. My clog was very tiny and kept anything from flowing through the brush, except air. Hope it helps!
