Paint brands
    February 2015
Paint brands
Posted by acctingman on Wednesday, October 7, 2015 4:13 PM
Just curious to know what brand(s) the pros here use for acrylics? Is one better than the other? I'll be airbrushing and doing heavy weathering.
For weathering products.....whom do you prefer?
Thanks in advance!
Posted by Bish on Wednesday, October 7, 2015 4:17 PM
I mainly use enamels, but i do also use Acrylics. My main brand is Tamiya but i have also taken to useing vallejo recently.
For weatheirng, i mainly use AK interactive but do have some MiG oils and pastels.
    February 2015
Posted by acctingman on Wednesday, October 7, 2015 4:27 PM
Is there any advantages/disadvantages to using acrylics over enamels? Is one type of paint better for armor or aircraft?
Posted by Bish on Wednesday, October 7, 2015 4:34 PM
I use enamels for both. The set I use, Xtracolour, is gloss, so no need to add a gloss coat, and it comes in the colour ranges I use. The main drawback of Enamels is the smell and they are more harmful than Acrylics.
There is also an issue with drying time with Enamels supposedly taking longer, but I have had them touch dry in less than 24 hours. I mainly use the Acrylics for painting figures and small bits on the model, tracks, tools etc or where I don't want to add a future coat before adding oil/enamel washes. Its all really down to personal preference.
If you are forced to paint in the house without separation from others living there, I would certainly go for Acrylics.
    February 2015
Posted by acctingman on Wednesday, October 7, 2015 4:41 PM
Thank you Bish!
    March 2013
Posted by patrick206 on Wednesday, October 7, 2015 6:30 PM
I use both acrylic and enamel, even some lacquer. My preference for acrylic is based on quality of finish, ease of cleanup and very little smell.
Enamel requires either lacquer thinner or enamel thinner for reduction to spray, as well as cleanup. Awful odor, not very healthy either. I use them only because I have a dedicated workshop with spray booth and powerful fan, positive airflow via sealed four inch hose to the outside.
Acrylic flows out nicely, fully dry usually in two days or less, next to no odor, but still I only spray at the booth. Easy cleanup with water or alcohol, (EXCEPT VALLEJO,) water works OK with Vallejo, but alcohol reacts and turns it into a thick, stubborn mess that's difficult to remove, except with lacquer thinner or acetone.
My preference is Tamiya acrylic, very consistent batches and great quality finish, durable as well. Larger bottles than most others, cost of use is less. Tamiya is not very good for brush painting, must use flow agents to avoid brush strokes. Vallejo Model Color is good for brushing, Model Air for spraying. No experience with other brands.
Tamiya offers a thinner that works very well, X-20A. They also offer a lacquer thinner that some swear by, I haven't tried it yet, but regular lacquer thinner works well in it.
Hope this helps.
Patrick
Posted by Don Stauffer on Thursday, October 8, 2015 9:26 AM
Bish
I have had gloss enamels take three or four days to dry in certain weather conditions, but I like enamels otherwise.  So I built a heated drying box, and even gloss enamels now dry in less than a day.
    November 2010
Posted by Eagle90 on Thursday, October 8, 2015 9:44 AM
Both have their advantages and disadvantages.  For me the longer drying time and more intense clean up with the enamels, is the downside.  But the acrylics can dry TOO fast!  So when using an AB, you have to watch your tips, the acrylics dry very quickly.  My "rule of thumb" is I use acrylics to AB (mostly Tamiya), and enamels for hand painting.  But that is just me.  Best bet is to get a few of each brand and type and try them out yourself.  You'll make your own conclusion..and it will work for you! Then you can teach us!  LOL!
Eagle90
    October 2015
Posted by TomcatGuy on Thursday, October 8, 2015 11:12 AM
Laquer is your friend. If someday I can no longer get Mr. Color I'll quit the hobby. The beauty of lacquer is it dries faster than enamel and it can be pushed furthure than enamel and most certainly farther than acrylic. Solvent based acrylics like Tamiya and Mr. Hobby are really great, and a nice second option. The problem with Tamyia is poor color choice. The problem with Mr. Hobby is avaliability in the US. I find all other acrylics pretty much useless because they don't spray well at highly thin levels needed for the airbrush based weathering I do.
    September 2006
Posted by the Baron on Thursday, October 8, 2015 12:24 PM
acctingman
Thanks in advance!
Which brand of acrylics?  It depends.
I have Tamiya, Vallejo, Andrea, Model Master, and craft store acrylics.  I will use one or the other, depending on the job.
For painting figures, Andrea and Vallejo are purt near unbeatable.  They were designed specifically for hand-painting of miniatures.  They go on easy, dry to an excellent finish and cover very well.  Vallejo also makes a series designed for airbrushing, but I haven't tried those, and I haven't tried airbrushing the Andrea and Vallejo paints that I do have. So I can't speak to how well they may perform when airbrushing.
For ordnance and for figures, I also use Tamiya acrylics.  They work very well with an airbrush; they are formulated for airbrushing, I have been told.  They also work best, in my experience, when used with Tamiya's proprietary acrylic thinner, whether you want to apply them with an airbrush, or brush them on by hand.  I have heard that they can be thinned with lacquer thinner for airbrushing, too, but I haven't tried that .  I have tried water, and isopropyl, to thin my Tamiya acrylics, and got very poor results.
Model Master acrylics I also use for ordnance and for figures.  On figures, I will often brush them right from the jar, no thinning, onto the subject.  On ordnance, I'll airbrush, thinning them with isopropyl.  They work OK, too.
And the craft store acrylics serve as good utility paints.  I've thinned them with water or with isopropyl, for hand-brushing and for airbrushing.  I found that they're not as good for airbrushing, because they tend to have coarsely-ground pigments, and so the resulting finish is a little rough.  But they are great for washes and for other weathering techniques.  And the work well enough for figures.
For weathering products, I make my own.  Although I appreciate that the commercial makers take the guesswork out of it, and that appeals to new guys and some experience modelers, I'm not about to pay Mig and the rest for things I can make myself.  Pastel chalks provide weathering powders, and paints and thinners provide washes and weathering fluids.  I use oils for filtering.
Hope that all helps!
    December 2011
Posted by Chrisk-k on Thursday, October 8, 2015 6:50 PM
Although I use enamels for detail painting and dry-brushing, I airbrush only acrylics.
My favorite is Tamiya; It always works and very easy to clean.
My 2nd favorite is Testors.
My LEAST favorite is Vallejo; I have to make it work.
Iwata HP-CS | Iwata HP-CR | Iwata HP-M2 | H&S Evolution | Iwata Smart Jet + Sparmax Tank
