Tamiya Paint Crossover
    January 2016
Posted by Hunter on Saturday, February 6, 2016 8:02 AM
Hello everyone,
I am currently working on a Japanese Zero from Tamiya and the main two colors are AS-2 "IJN"Light Gray and AS-21 "IJN" Dark Green. My problem is my local hobby shop and Hobby Lobby do not carry the Tamiya AS paint series. I have the complete X & XF series and was wondering if anyone knew what X or XF colors would be a match to those two AS colors?
Thank you for any help in this matter
Hunter
Hunter
    May 2013
Posted by hogfanfs on Saturday, February 6, 2016 9:01 AM
Hunter,
Here is a Tamiya paint guide for Japanese Aircraft:
JAPANESE AIRCRAFT
XF11 JN green Upper side of the Navy plane
XF 12 JN grey Lower side of the Navy plane
XF13 JA green Upper side of the Army plane
XF14 JA grey Lower side of the Army plane
XF16 Flat aluminium Silver fuselage without coloring
X13 Metallic blue Interior of the plane
I'll will try to post the PDF file, it has a lot of information on how to mix Tamiya colors.
Edit: Message me your email address, I have two color charts and the mixing chart in PDF format. The forum does not allow attachments such as PDF or Word.
Hope this helps...
 Bruce
 On the bench:  1/48 Eduard MiG-21MF
                        1/35 Takom Merkava Mk.I
    January 2016
Posted by Hunter on Saturday, February 6, 2016 2:14 PM
Bruce,
Thank you very much sir. This is perfect and a big help. I appreciate you looking at my thread. Saved me a lot of "hunting time" for this.
Take care,
Hunter
Hunter
    July 2004
Posted by stikpusher on Saturday, February 6, 2016 2:23 PM
You may want to have a look at Gray Green XF-76 also. That color was supposedly matched to later research color for the Zero and was released with their new 1/32 Zero kits as a result. XF-71 for the cockpit color, and XF-70 for a topside green if you do a two tone scheme.
http://www.tamiyausa.com/articles/ln/72/XF-chart-10ml.pdf
U is for URANIUM... BOMBS!
N is for NO SURVIVORS...
       - Plankton
LSM
    May 2013
Posted by hogfanfs on Saturday, February 6, 2016 2:33 PM
I should have posted that those are not direct color matches with the AS colors. There will be some variation in the color.
 Bruce
    April 2008
Posted by spiralcity on Saturday, February 6, 2016 3:18 PM
ebay is a great source. I took alook and found AS-21 in rattle can only. I'm not sure how you feel about rattle cans. As-2 also only in rattle can. Links are below.
http://www.ebay.com/itm/TAMIYA-AS-21-Spray-Paint-Dark-Green-2-IJN-3-oz-86521-TAM86521-/151949283432?hash=item2360e21068:g:dTsAAOSw-zxWnqbC
http://www.ebay.com/itm/Tamiya-86502-Aircraft-Spray-AS-2-Light-Gray-/391363022623?hash=item5b1f0dcf1f:i:391363022623
    January 2013
Posted by BlackSheepTwoOneFour on Saturday, February 6, 2016 3:53 PM
Kinda pricey for Tamiya rattle cans on eBay. Scalehobbyist sells them fat less. Why not ask your LHS if they could order them for you? Or order from any online hobby store.
    January 2016
Posted by Hunter on Saturday, February 6, 2016 6:28 PM
stikpusher
Thank you Stik....Those colors look like they will match up. When I looked up the two tone paint job I had to make sure I was looking at the Navy colors not the Army colors. They are slightly off in tone.
Hunter
    January 2016
Posted by Hunter on Saturday, February 6, 2016 6:31 PM
Hello BlackSheep,
I found them on Scalehobbyiest site a couple of days ago. I was hoping to find them in a 18 or 23ml jar. But if I need to use a rattle can I will. My LHS would take to long...much faster if I do it. Thank you for the help and Info.
Hunter
Hunter
    January 2016
Posted by Hunter on Saturday, February 6, 2016 6:34 PM
spiralcity
Hey SpiralCity,
Thank you for the links, it looks like I'll have to get the rattle cans so I properly finish this build. I want to make sure I use the right colors. Again, thank you for your help. Greatly appreciated.
Hunter
Hunter
    November 2003
Posted by tempestjohnny on Monday, February 8, 2016 6:46 PM
The grey color that was used on Zeros had a definite green tone to it. Also depending on if the Zero you are working on was made by Mitsubishi or Nakajima will decide on some detail color differences. I have a bunch of Tamiya mix charts to make the right shade of colors. Downside is you have to mix. John
Also the control surfaces are a different shade then the metal airframe
    November 2003
Posted by tempestjohnny on Monday, February 8, 2016 6:51 PM
I have about 5 pages of reference for mixing Tamiya colors to existing military colors. Let me know if you're interested
    January 2016
Posted by Hunter on Monday, February 8, 2016 7:46 PM
tempestjohnny
TJ -
Thank you so much for your time and help in this matter...I went ahead and ordered the rattle cans so I put the right colors on the build. FYI since you were so informative...Mitsubishi A6M5 Japanese Zero.
Hunter
