al clad alumium
    March 2016
al clad alumium
Posted by ardvark002 on Wednesday, August 24, 2016 8:28 PM
Hi all, Is it possible to use another color under al clad alumium besides gloss black, and get a good result?    thx aardvark
    May 2013
Posted by Snibs on Wednesday, August 24, 2016 8:57 PM
Hi aardvark.
You could use any gloss colour but anyone's guess what it would turn out like, only one way to find out. Big Smile
Mick.
Some stuff that might be interesting.
https://sites.google.com/view/airbrush-and-modeling/home
On The Bench.
Tiger 1 and Tooheys.
    May 2006
Posted by Shipwreck on Thursday, August 25, 2016 4:16 AM
Mick is correct, but I am not sure it would have to be gloss. The base coat does not have to be solid either. I generally use Tamiya TS-30 Silver Leaf, either straight out of the can and/or decanted for my airbrush, as a prime coat. If you look at a real AMF aircraft, it does not have a solid even finish. You can represent this by various blacks, grays, and some blues, or what ever blotches of paint. You can do some of your panel variation this way. The TS-30, or what ever, is sprayed over the entire model, then the selective pre-shading, and finally the Alclad with its panel variations.
On the Bench:
Revell 1/96 USS Constitution - rigging
Kinetic 1/48 YF-104A 5+2957
Trumpeter 1/350 USS Hornet CV-8
Revell 1/48 B-1B Lancer Prep & Reasearch
    May 2006
Posted by Shipwreck on Thursday, August 25, 2016 5:08 AM
Be aware that Alclad II is a lacquer based paint; which means any base or pre-shading paint must be compatible with it. I think that enamel pre-shading will work; but test it first.
On the Bench:
Posted by Bish on Thursday, August 25, 2016 5:16 AM
You only need a gloss base for the High Shine Alclads. Before i switched to Alclad primers, i used Humbrol black enamel and that worked fine.
Posted by Don Stauffer on Thursday, August 25, 2016 9:08 AM
Bish
I agree.  The polished aluminum is critically dependent on the undercoat- other shades less so.  I have used gloss blue under polished aluminum and it worked fine.  I have also used gloss yellow under a couple of Alclad shades to get a sort of magnesium effect- not quite as good, but not bad.  Easy enough to experiment with different colors and sheen.
I also use enamel- Testors gloss black (the two colors I used above were also enamels).  I have a drying box, and I make sure paint is hard and dry before putting the Aclad over it.
    January 2006
Posted by DiscoStu on Thursday, August 25, 2016 1:21 PM
As has been stated, you only need to use black on the high shine Alclad lines.  For just plain-ol' aluminum I use Mr. Surfacer 1500 as a primer.  Never failed me yet.
"Ahh the Luftwaffe. The Washington Generals of the History Channel" -Homer Simpson
    July 2013
Posted by modelmaker66 on Friday, August 26, 2016 1:03 AM
I have used Alclad II over a primer base of Vallejo black acrylic primer that is a satin finish with great results. The high shine of chrome needs a gloss base supposedly, you could even apply over a brushed on future coat.
Posted by Don Stauffer on Friday, August 26, 2016 9:44 AM
modelmaker66
The high sheen colors- chrome and polished aluminum- do need a dark color beneath them.  The secret to getting the gloss sheen is to put it on very thin. Thus, the undercoat is very important and the color is quite discernable.
