Paint Question (But Not Exactly Model Related)
    August, 2017
Posted by Doc Ward on Wednesday, September 13, 2017 8:11 PM
I was given an older electric guitar as a gift. Since I won't be seeing the person who gave it to me much, if any in the future, I had him sign it with a Sharpie. Since I would like to protect the signature, I am trying to figure out the best way to protect it. I believe it is a polyurethane finish on the guitar.
I have a bottle of Future that I could use, although I have never airbrushed it. The other option readily at hand is a rattle can of clear gloss lacquer. Are there any other options I could look to?
Gotta say, doctor, your talent for alienatin' folk is near miraculous.
    July, 2004
Posted by stikpusher on Wednesday, September 13, 2017 8:36 PM
Future airbrushes easily as is. No thinning or additions needed. Otherwise use your favorite preferred clear coat. Just check to see that whatever you do use will not attack the base layer as some lacquers may do.
U is for URANIUM... BOMBS!
N is for NO SURVIVORS...
       - Plankton
LSM
    August, 2017
Posted by Doc Ward on Wednesday, September 13, 2017 8:56 PM
stikpusher
With a guitar, it isn't easy to find an inconspicuous spot, so it might be smarter to just avoid the lacquer altogether. Once it dries, will the Future be durable? It would pretty much just rub against my clothing and the like.
    July, 2004
Posted by stikpusher on Wednesday, September 13, 2017 9:42 PM
Future is made for floors and all the use they get. But then again, you coat your floor with the stuff every so often to maintain the shine. Us modelers just happen to use the stuff and its' not so exposed to contact in our case.
How about some sort of furniture clear coat varnish? That would likely be more robust.
       - Plankton
LSM
    August, 2017
Posted by Doc Ward on Wednesday, September 13, 2017 9:47 PM
stikpusher
I was hoping to use a spray or my airbrush, to lessen the risk of smearing the signature. I would have to do some experimenting to use clear varnish or polyurethane through my airbrush, I would think. I've not heard of it being done, although I am sure it has been.
I will give the Future a try, I hadn't thought about the fact that it is used for floors. It should work fine, I would think.
Thanks for the input!
    November, 2008
Posted by mrmike on Wednesday, September 13, 2017 11:54 PM
Just a note of caution...Sharpie brand markers can bleed, sometimes very badly depending on the solvent used in the finish applied. An independant test of finish would be required to set my mind at ease before comitting to the final. BTW, Future is a "wax", not a finish coat as in poly or other oil based coatings, or a lacquer product.
I don't mean to put too fine a point on this, but I have refinshed guitars and don't want to see you disappointed with your signature instrument.
    September, 2012
Posted by GMorrison on Thursday, September 14, 2017 1:07 AM
CAUTION WILL ROBINSON!
Sharpie ink is weird, and runs at the slightest sign of rain.
You can try a test, but I will bet you that the best option here is to leave it be as is.
    July, 2004
Posted by stikpusher on Thursday, September 14, 2017 1:36 AM
Future is an acrylic coating, not a wax.
       - Plankton
LSM
    April, 2004
Posted by Jon_a_its on Thursday, September 14, 2017 2:36 AM
Get same sharpie, test sign on the back where it won't be seen, use your prefered lacquer on the back.
Make sure it doesn't react to the sharpie before doing the front sig.
East Mids Model Club 28th Annual Show 20th MAY 2018
 http://www.eastmidsmodelclub.co.uk/
Don't feed the CM!
    June, 2014
Posted by bluenote on Thursday, September 14, 2017 8:51 AM
I would strongly recommend you take your guitar to a guitar shop and ask them.  They probably see guitars all the time with signatures on them and they'd be best to recommend a solution.  I really wouldn't recommend spraying lacquers, floor polish, etc on a guitar without knowing for sure how it'll react.  A guitar's finish is much different then a model.  (or it may be different, I don't know)
    August, 2017
Posted by Doc Ward on Thursday, September 14, 2017 2:09 PM
The signature is on the back, so if it does smear, it won't be incredibly noticeable. From everything I can find, Epiphone has been using polyurethane as a finish for many years. It sounds like I want to avoid lacquer, because I don't know how it will react. I'm thinking that if I spray a couple of coats of Future on, keeping the coats light, I should be in good shape. I will let everyone know.
    August, 2017
Posted by Doc Ward on Sunday, September 17, 2017 2:36 PM
Just thought I would give that update I promised. As I mentioned in my original post, the guitar is an older one, meaning it has some blemishes. Some dings, and on the back some rub marks from buttons or belt buckles and the like.
When I looked at how I wanted to go about hitting it with the clear, I decided I wanted to leave the "history" there as much as possible, and just add to it a little. Instead of doing a full masking job, I just sprayed a patch where the signature is, covering it completely. The gloss of the Future is greater than the original gloss, and surprisingly, it made the signature really stand out!. No running, no smearing, it looks good. On the downside, some of the marks and dings are around the area where it was signed, and I managed to get a bit of dust in the clear (It wouldn't fit in my booth, naturally). However, as far as I am concerned, I consider it a success.
If I can track down a working camera, other than the poor one on my old dumb phone, I will try to upload a pic or two.
SUBSCRIBER-ONLY CONTENT
