Spray booth fan, do I really need to worry about an explosion?
    August 2017
Posted by Seth Krumm on Sunday, October 15, 2017 10:49 AM
We've all heard the horror stories about people blowing themselves up while painting their car on these spray booth fan threads, but I have never heard anyone actually saying it happened with an airbrush. I just can't imagine the minuscule amount of fumes produced by an airbrush being able to produce a remotely dangerous explosion, at worst no more than a ruptured drier tube.
People usually recommend squirrel cage fans, but their CFMs are pretty low for their price, and I'm going to need a lot of CFM for my booth since the fumes have to go through 20 feet of hose. I have seen plenty of modellers (experiences ones too) using range hoods, box fans, and even $10 walmart fans to exhuast airbrush fumes without any problems and none with problems.
So, is there a serious risk of using a cheap exhuast fan? I was thinking of using an inline duct fan or a bilge blower. I've also heard of people using duct collectors, are those explosion proof?
Tags: spray booth
    March 2007
Posted by armornut on Sunday, October 15, 2017 11:13 AM
You need 3 things to create a fire, heat, fuel, oxygen( normal air). All 3 are present in a fan however you also need the right fuel/ air mixture for fumes to ignite. Odds are pretty good if you can touch the fan motor bare handed and not suffer a burn you do not have enough heat. You are correct in thinking that there is a small amount of fumes that are expelled from an airbrush, by the time you build up enough consentration to ignite you probably will have passed out. One thing I would do is make sure the fan motor is clean and free of dust and lint, these materials can wick moisture from the air and create an arcing issue. I have painted both enamals and acrylics for years without an exhaust fan and HIGHLY RECOMMEND using one.
we're modelers it's what we do
Posted by Don Stauffer on Sunday, October 15, 2017 12:19 PM
Some fans have commutators or brushes where sparking can occur.  These are the kind to worry about, even if they do not feel hot to the touch.  I always use the brushless AC muffin fan type.
    October 2008
Posted by Don Wheeler on Sunday, October 15, 2017 3:23 PM
As long as you move enough air that you don't exceed the LEL (lower explosive limit) of the vapors, you don't have to worry about sparks.  If you do exceed LEL, you need to worry about all sources of sparks, including static electricity.
Most AC fans have brushless shaded pole motors.
Don
https://sites.google.com/site/donsairbrushtips/home
A collection of airbrush tips and reviews
Also an Amazon E-book and paperback of tips.
    August 2017
Posted by Seth Krumm on Sunday, October 15, 2017 5:15 PM
(I unsuccesully tried to reply to a comment)
    August 2017
Posted by Seth Krumm on Sunday, October 15, 2017 5:21 PM
So will a brushless AC motor be good? I happen to have a blower used for an inflattable water slide lying around. I have no idea why they used a brushless motor but I'm 100% sure that it is indeed brushless. Moves a massive amount of air and provides great pressure, would be perfest for me since whatever I use will have to move air through 25 feet of flex duct.
    March 2007
Posted by armornut on Sunday, October 15, 2017 5:34 PM
That sounds perfect. As stated above the safer the better. IMHO if you achive the right mixture of air, fumes and somehow get a spark you would probably be overcome physically. THAT BEING SAID if you can safely exhaust fumes DO IT, lungs are hard to fix.
    July 2012
Posted by littletimmy on Sunday, October 15, 2017 5:52 PM
Just so you know: The motor you are using was never ment for continuous use.( it will probably burn out at a most "inopertune" moment.)
Seth Krumm
Unless you are talking about the kind that are used for those "bouncy house's" .... like you would rent for you're kid's birthday.
In any case, you will probably never pump enough paint through a fan to cause a "major" explosion. A small fire .....maybe. (but not very likely)  Only if the fan has a defect.  But unless you're airbrush has a 5 gal. cup  i wouldnt worry about it. ( By all means keep a fire extinguisher handy..... I have been wrong ..... from time to time.)
 Dont worry about the thumbprint, paint it Rust , and call it "Battle Damage"
    August 2017
Posted by Seth Krumm on Sunday, October 15, 2017 7:32 PM
littletimmy
Seth Krumm
Nope, it's one for continous use :)
    January 2013
Posted by BlackSheepTwoOneFour on Sunday, October 15, 2017 8:33 PM
Why not buy an airbrush spray booth instead? I got mine for around $100 It comes with its own vent hose and fan with filter.
    March 2015
Posted by JohnnyK on Sunday, October 15, 2017 11:02 PM
The motor in the blower of my spray booth is not in the path of the air flow. That means that the paint residue never contaminates the motor.
I made my own spray booth with parts from Ikea. Go here:
http://cs.finescale.com/fsm/tools_techniques_and_reference_materials/f/18/t/171600.aspx
    July 2013
Posted by modelmaker66 on Monday, October 16, 2017 12:51 AM
Exactly!  How much could you really be saving instead of buying a unit made for it. Why risk it and woder all the time if it is safe. Way to go Black Sheep!
    January 2017
Posted by damouav on Monday, October 16, 2017 3:06 AM
My diy uses a large cfm capacity bathroom exhaust fan, with a 1.2m long hose attached, it works OK.
I used a filter in a attempt to stop larger particles of paint, but it significantly reduces the fans limited ability to extract the fumes, so It will soon be removed.
From memory the fan can move about 250-270 cfm, the ducting was old ac ducting.
I don't belive the cheap AB booth's will have suficient ability to push the quantity over the required distance, from my reasearch they use 12v computer fans that are pretty useless apart from moving air inside an enclosed computer case.
Good luck.
In Progress
1/48 Tamiya P47-D Bubbletop
1/48 Hobby Boss TBF-1C Avenger (on hold)
Pending
1/48 Roden S.E.5a
1/48 Airfix Walrus
Posted by Wingman_kz on Monday, October 16, 2017 5:55 AM
I've used a Dayton blower in my booth for years and never had a problem, even when using aerosols. I don't remember the proper term but it isn't an explosion proof version. Not to say that nothing could ever happen but it hasn't. Don't remember the number either but it's around 325cfm. There is a fellow named Klaus Raddatz that I knew from another message board that had instructions posted online for building your own booth but I can't find the complete article now. He had a formula for figuring what size fan you would need. It took into account booth size, ducting diameter and length plus bends or elbows. If you have a small booth, vented directly to a window then no, it doesn't take much to move air. But, if you have a larger booth with a longer run of ductwork it takes much more fan than you may think to be effective. If you have a long run to make then smooth tubing would be much better than flex hose. But, just my opinion.
    March 2015
Posted by JohnnyK on Monday, October 16, 2017 2:38 PM
This is the blower that I use in my spray booth. The motor is outside of the air stream so there is no chance of an explosion. I also use a filter in the spray booth. The filtered air is exhausted through an exterior wall .
    January 2013
Posted by BlackSheepTwoOneFour on Monday, October 16, 2017 6:22 PM
damouav
Good luck.
I disagree.
    January 2017
Posted by damouav on Monday, October 16, 2017 9:26 PM
I thought you would.
In Progress
Pending
1/48 Roden S.E.5a
1/48 Airfix Walrus
    January 2013
Posted by BlackSheepTwoOneFour on Tuesday, October 17, 2017 2:04 PM
damouav
This response is unnecessary.
    January 2017
Posted by damouav on Tuesday, October 17, 2017 2:59 PM
damouav
That response was also anticipated.
Every try to push a quantity of air via a 26ft tube with a 12v computer fan...
Thought not.
In Progress
Pending
1/48 Roden S.E.5a
1/48 Airfix Walrus
    July 2013
Posted by modelmaker66 on Tuesday, October 17, 2017 10:16 PM
damouav
damouav
Thought not.
Savage!
    January 2017
Posted by damouav on Wednesday, October 18, 2017 5:06 AM
No more or less than I recieved from that person in the past.
Any who, moving on.
In Progress
Pending
1/48 Roden S.E.5a
1/48 Airfix Walrus
Posted by Don Stauffer on Wednesday, October 18, 2017 9:03 AM
I suppose I should have said this earlier, since it is a closer answer to the OP's question.  I have a nice spray booth, but I only use it when I am painting with rattle cans.  I do not use it for airbrush work- I just clear off the workbench a bit and work right there.
I agree that the amount of fumes from an airbrush is pretty small.  I don't think the thinners used with acrylic and even with turpentine (for enamels) is that dangerous in those volumes.  I am not sure about lacquer thinner, though.  I do try to reduce the volume of gases during the cleaning, however. I have a homemade "cleaning station" that traps the vapors of what I run through my airbrush while cleaning.
    June 2012
Posted by Compressorman on Wednesday, October 18, 2017 2:08 PM
Don Stauffer
Hi Dan,
Would you mind describing this? I have long wanted to build one of these.
Thanks!
Chris
Posted by Don Stauffer on Thursday, October 19, 2017 8:50 AM
Compressorman
Don Stauffer
Hi Dan,
Thanks!
Chris
Well, I will have a chance to build a new one, so will take pictures while I do.  My cleaning station sat on the edge of the bench right below where I keep my airbrush.  I use a suction feed (bottle type) and the bottle adapter/bottle fell out when I picked up the airbrush day before yesterday.  It hit cleaning station on way down, knocking both to floor, and destroying my cleaning station.
As a summary, since it will take a few days to make a new one:
I use a glass jar (because I sometimes clean with lacquer thinner.  I make a necked top from 1/2 or 3/4 inch PVC pipe fittings, including a 45 degree corner fitting.  A very short length of pipe comes out of that fitting, with a piece of plastic covering the end. A 5/16 inch hole in the end is just a bit bigger than the tip of my airbrush.  I glue the pipe buildup in a hole I have created in the jar lid, and poke a little hole in the lid as a second hole, so the jar can vent pressure without competing with the incoming airflow.  Takes a glass jar (pint or half-pint or so) and about a buck or two's worth of pvc pipe fitting.
BTW, the station had several ounces of used thinner in it (which I save to put in my brush cleaning jar), and cleaning that off the floor was no fun!
    March 2010
Posted by ACESES5 on Friday, October 20, 2017 8:13 PM
You also forgot the 4th thing you need for a fire is static electricity I've been using the same fan in my paint booth since the early 70's have had no probluems. My fan motor is as far as I know brush type motor,It's the type used in furnace blowers. I can understand the concern here with all the new paints on the market that are no longer using a petroleumn base ie; lacquer base paints I think our biggest worry would be WEAR YOUR RESPERATOR when you spray.2 cents                        ACESES5
