Chrome Erosion on Iwata Eclipse
    August, 2017
Posted by laskdjn on Monday, December 04, 2017 12:31 PM
Realized I put this in the wrong forum a bit ago, so I'm moving it here:
Hey guys,
So, I'm on my second Eclipse now in 4 or 5 months, the first one was sent back to Iwata and they replaced it, but it's happening again, I already contacted Iwata and they said they'd replace it again, but I'm trying to root down to the meat of the issue, so here goes.
I only shoot Vallejo paints and use Vallejo thinner.  I only clean with isopropyl alcohol and Iwata airbrush cleaner, however, no matter what I do, within less than a month, the bottom of the color cup starts to lose its chrome plating and turns a copper color(I can only imagine the metal under the chrome is copper.  I never use any windex or ammonoid products(unless its in the Vallejo paint or thinner).
The way I mix and shoot is as follows:  I put thinner then paint into the cup then I mix it in the cup with an old brush and then shoot as normal.  To change colors, I pour in some isopropyl alcohol use a paper towel to get the paint residue off the sides of the color cup and use the same brush to get all the bits of semi-dried paint out of the corners in the bottom of the color cup.  For a deeper clean, I disassemble the front end and clean the front end with isopropyl alcohol, an interdental brush, and q-tips.
So, my questions are these:  What causes this?  And the question to end all, how do I prevent it?
I find that as the chrome continues to wear, my airbrush clogs faster, requiring me to blow out the needle more often.  And, it also makes the airbrush more difficult to clean in that the paint adheres to the bottom of the color cup stronger.
Any insight would be greatly appreciated.
    May, 2013
Posted by Greg on Monday, December 04, 2017 12:45 PM
I don't know about the chrome wearing off the bottom of the paint cup. Mine does too and I always figured it was normal, maybe you're right, maybe it's not.
But you mentioned running iso through your brush between Vallejo colors. Vallejo and alcohol don't get along and I'm surprised you are not reporting clogging and gumming-up problems.
-Greg
    March, 2003
Posted by Tojo72 on Monday, December 04, 2017 3:05 PM
True,usually alcohol turns Vallejo to gunk.
    July, 2013
Posted by modelmaker66 on Monday, December 04, 2017 3:06 PM
Ammonia will do that in time. If you use a cleaner that has ammonia like windex it will do it. It is not covered by warranties but does not effect performance. So it is your doing probobly, not a defect.
    January, 2017
Posted by damouav on Monday, December 04, 2017 3:41 PM
I've had my Iwata Eclise for almost 12mths and use my own cleaner for acrylics (IPA, Windscreen Cleaner) and Laquer Thinners to clean my AB. I personally have not seen any signs of the chrome being removed from the color cup.
Do you have any pictures?
In Progress
1/48 Hasegawa P51-D
1/48 Hobby Boss TBF-1C Avenger
Pending
1/48 Tamiya P47-D Bubbletop
1/48 Roden S.E.5a
1/48 Airfix Walrus
1/48 Hasegawa P38-L
    August, 2017
Posted by laskdjn on Monday, December 04, 2017 5:08 PM
Greg
I don't use IPA for thinning, I use it for cleaning and in my experience with cleaning Vallejo paint in between colors, it works great.
modelmaker66
The only way ammonia could've gotten into my airbrush is if it's in vallejo's thinner or model air paint.
damouav
I can get pictures when I come home from work.  I specifically don't use Windex or any other window cleaner because it has ammonia in it.
    December, 2013
Posted by route62 on Monday, December 04, 2017 11:58 PM
If the chrome is coming off but the underlying metal is not showing signs of corrosion and the airbrush is performing as expected, does it matter then?
I have airbrushes that are 15+ years old.  Much of the chrome has worn off all over the airbrush inluding the cup.  They still perform and only seals and needles have been replaced.
Keep using it and if you see a significant degrade in performance or corrosion on the exposed metal where the chrome is gone then you have a case for replacement.
    January, 2017
Posted by damouav on Tuesday, December 05, 2017 3:11 AM
route62
After having a quick look at my Eclipse it appears that some of the chrome has indeed worn away at the bottom of the paint cup. I called the dealer where it was purchased from and he said All AB do the some thing over time, all ab's.
It works the same as it did 12 months ago, it has no corrosion and will most likely work the same in another 10 years.
As route62 has pointed out, just keep using it.
In Progress
1/48 Hasegawa P51-D
Pending
1/48 Roden S.E.5a
1/48 Airfix Walrus
1/48 Hasegawa P38-L
    April, 2004
Posted by Jon_a_its on Tuesday, December 05, 2017 3:56 AM
I have some wear of the chrome to brass in the colour cups of:
my Iawata CS, 9 yrs old
my Badger 100 small cup, 20+ yrs old
and my on my Badger 150 original seperate colour cup, 25+ yrs old.
I've never used Ammonia cleaner on the Iwata.
So long as the needle, headset, & air valves are ok, then you should be good to go.
East Mids Model Club 28th Annual Show 20th MAY 2018
 http://www.eastmidsmodelclub.co.uk/
Don't feed the CM!
    August, 2017
Posted by laskdjn on Tuesday, December 05, 2017 9:25 AM
So, perhaps I'm just being paranoid.  Thank you all for the excellent advice and for sharing your experiences.
    August, 2017
Posted by laskdjn on Tuesday, December 05, 2017 2:21 PM
On a side note, would the nickel on an H&S Evolution be more or less durable than the chrome on an Iwata Eclipse?
    October, 2008
Posted by Don Wheeler on Tuesday, December 05, 2017 3:13 PM
laskdjn
Chrome is harder than nickel, so it should wear better.  But, it mostly depends on the thickness of the plating, and both are very thin.  I suspect it is especially thin in the recess of the cup.
I've heard that the gold plating on the Evolution handle wears away fairly fast.
Don
https://sites.google.com/site/donsairbrushtips/home
A collection of airbrush tips and reviews
Also an Amazon E-book and paperback of tips.
    August, 2017
Posted by laskdjn on Tuesday, December 05, 2017 3:34 PM
Thanks for your prompt response.  So, if I wanted to go the evolution route, I'd definitely spend the extra 50 bucks or whatever and get the CRplus version.
    October, 2008
Posted by Don Wheeler on Tuesday, December 05, 2017 4:18 PM
laskdjn
Well, I wouldn't.  To me it's just an appearance thing unless you are alergic to nickel.
Don
    August, 2017
Posted by laskdjn on Wednesday, December 06, 2017 8:52 AM
Oh, I thought the chrome being harder and more wear resistant would mean the airbrush would last longer.
    October, 2008
Posted by Don Wheeler on Wednesday, December 06, 2017 12:31 PM
Whether chrome or nickel plated, a good quality airbrush that's taken care of will last you many years.  The parts that wear are easily replaced.
Don
    August, 2017
Posted by laskdjn on Wednesday, December 06, 2017 1:56 PM
Don Wheeler
Don
If I decide to purchase a new airbrush, I don't want something similar happening to it as what happened to my Iwata Eclipse, it was disheartening to have that occur after only a few weeks of use, especially when I try to completely avoid the use of anything with ammonia in it.
    January, 2006
Posted by Paul Budzik on Wednesday, December 06, 2017 2:22 PM
Having had conversations with HS ... the only reason for the chrome plating was because some people reported allergic reaction to the nickel.  Other than the plating, the airbrushes are identical.
As to the original post ... not sure what you guys are doing, but I have 3 Eclipses HP-CS ... that I have had for years and none of them show any signs of plating wearing off ... but I only clean with lacquer thinner.
Paul
    August, 2017
Posted by laskdjn on Wednesday, December 06, 2017 6:08 PM
Paul Budzik
That's the thing, Paul, I don't know what I'm doing wrong either, but this is twice in a row.
I outlined everything i do exactly in my original post
    October, 2008
Posted by Don Wheeler on Wednesday, December 06, 2017 9:09 PM
It may be that Iwata is having a plating problem.  That they were willing to replace the airbrush might indicate that.  They could have just told you the wear was normal.
Don
    January, 2017
Posted by damouav on Wednesday, December 06, 2017 11:14 PM
Paul Budzik
I had been using a home made cleaner (IPA & Car Windcreen Cleaner and Distilled Water) which must contain ammonia, which I left a few drops in the my AB after cleaning. I think that is what caused it, but I clean with laquer thinners now.
In Progress
1/48 Hasegawa P51-D
Pending
1/48 Roden S.E.5a
1/48 Airfix Walrus
1/48 Hasegawa P38-L
    August, 2017
Posted by laskdjn on Thursday, December 07, 2017 9:17 AM
Don Wheeler
Don
Don, that could be, but I would like to know if my methods could contribute any culpability to the problem.
    June, 2014
Posted by Tanker - Builder on Thursday, December 07, 2017 3:15 PM
Hi;
 Reading this made me check my A.B.s closer .I don't use any brush with a color cup if I can help it . Never Have ! I use the Badger type with the bottles on the bottom or , if it's a big job, a proffessional De Vilbiss touch up A.B. Have had most for over forty years or more .No plating issue .
    August, 2017
Posted by laskdjn on Thursday, December 07, 2017 10:17 PM
Yeah, I've only been airbrushing for about a year now, but it's all been double action gravity feed
    August, 2012
Posted by Rambo on Friday, December 08, 2017 2:31 AM
That's odd I've had my Iwata eclipse for at least 6 years and have always used Windex to clean it with and the chrome still looks good
Clint
    August, 2017
Posted by laskdjn on Friday, December 08, 2017 8:09 AM
Rambo
Both outside and inside the color cup?
    July, 2014
Posted by Bakster on Friday, December 08, 2017 9:02 AM
modelmaker66
I second this. I experienced the same when I had used Windex as a cleaner. It strips the chrome off.
    August, 2017
Posted by laskdjn on Friday, December 08, 2017 11:05 AM
Bakster
modelmaker66
As I said earlier, I've never used windex or any ammonia product in my airbrush.
    August, 2012
Posted by Rambo on Friday, December 08, 2017 9:15 PM
Yeah inside and out only place where the chrome is coming off at is the inside of the removable lid that I never use
Clint
