compressor set up.
    May, 2018
compressor set up.
Posted by pppmario on Friday, June 08, 2018 9:48 PM
Just need some help with a compressor set up.
This is how I have it hooked up, regulator, water trap, and then hose hookup
https://photos.app.goo.gl/YM1kP22PPgJbpeY36
I have to go back and get and “end cap” for the bottom of the water trap, unless it is possible to mount it horizontally, that way the T junction would not be necessary.
I was told that this was the “venting” valve, (little red thing area), if so then I know vertically is the way to go.
I was also told that the trap should be further down the line that the condensation happens further down the line. If this is true, I have seen regulators with the water trap attached, so the further down the line comment doesn’t make sense to me.
So do i have the setup correct? Is my information about the horizontal and vertical setup?
Tags: compressor
On my workbench, my CAT!
https://photos.app.goo.gl/ERAw9Jvi3ovjDW5V6
    August, 2012
Posted by Rambo on Saturday, June 09, 2018 12:19 AM
That red striped thing is a valve core just like what you have in your tires on your car. Just my two cents here but if your using a tankless compressor you are going to be getting alot more water in the line than a tanked compressor would. But no mater where you put the trap it's going to work the same. I have a California air tools compressor then about five feet of line to my regulator and trap attached to my spray booth then about five feet of line to my airbrush. Even after running over a hour I get very little water in the trap and none through the other side in the line.
Clint
    October, 2008
Posted by Don Wheeler on Saturday, June 09, 2018 11:07 AM
Your moisture separator is the straight through type.  The connection at the bottom is the outlet.  That should go to your airbrush.  Otherwise, it will have no effect.  The red thing is the drain valve.  It needs to be at the bottom.
Your regulator is not really a regulator, just a flow valve.  It will limit air flow and work somewhat the same, but it's not really the same thing.
Unless you have a lot of humidity, I suspect you have enough metal between the compressor and separator to cool the air enough.
Don
I just did a little more research, and the Q&A on this  page says the blue end is the output side.  Apparently there are arrows on the body.
https://sites.google.com/site/donsairbrushtips/home
A collection of airbrush tips and reviews
Also an Amazon E-book and paperback of tips.
    May, 2018
Posted by pppmario on Saturday, June 09, 2018 6:12 PM
This is the item itself,
https://www.princessauto.com/en/detail/1-4-in-air-filter/A-p8602468e
From what i am reading, this item is for a "large" unit, ie automotive, connects to the gun not inline or permanetly attached as i did.
From what i have been looking at looks like i made several mistakes, going to return everything except the compressor and start over
looks like back to the drawing board.
    August, 2012
Posted by Rambo on Saturday, June 09, 2018 7:07 PM
My regulator and moisture trap are separate but the combo ones from HF are a good choice. https://m.harborfreight.com/14-in-Air-Line-Filter-Regulator-with-Gauge-68228.html
Clint
    October, 2008
Posted by Don Wheeler on Saturday, June 09, 2018 7:28 PM
Usually, compressors come with something like this, an all in one unit.  A real regulator has a diaphragm mechanism that will set and hold pressure.  If you can put a little distance via a hose or pipe between the compressor and the separator to cool the air, moisture separation will be better.
When I first started airbrushing, I had a compressor similar to yours and I just hooked my airbrush directly to it.  That type of compressor probably puts out about 25 to 30psi max. and it worked pretty well.  It's not ideal, but it will get you going.  You could experiment on some empty plastic bottles.
Don
    August, 2005
Posted by Phil_H on Sunday, June 10, 2018 12:14 AM
Looking at your compressor, it looks like a diaphragm type. Diaphragm compressors typically require a bleeder at some point in the outlet side to provide overpressure relief, otherwise you risk either rupturing the diaphragm or stalling the motor and possibly burning it out.
    May, 2018
Posted by pppmario on Tuesday, June 12, 2018 11:05 PM
Phil_H
Hi Phil_H, it is a diaphragm compressor, but it has an auto shutoff, to prevent overpressure, or so I am told. Got the user manual from Badger, in it they offer a bypass to the auto shutoff, will read that in depth before making any changes.
    October, 2008
Posted by Don Wheeler on Wednesday, June 13, 2018 11:32 AM
Here is what Phil is talking about:
This is from the Badger 350 manual.  The diaphragm compressors can stall if the output is blocked, and that's not good for them.
Don
    May, 2018
Posted by pppmario on Wednesday, June 13, 2018 2:36 PM
and this is from the 180-11 manual
