Spraying enamel over lacquer ?
    February 2013
Posted by tomwatkins45 on Tuesday, April 23, 2019 6:33 AM
I have heard that one way or the other is a no-no, but I can't remember which. Can I spray Model Master Enamel over Hataka Orange Line lacquer without causing a problem ? Incidently, this was my first time using the Hataka paint. I thinned it approx. 50-50 with their thinner, sprayed it at 20 psi using a Grex TG brush. It sprayed beautifully, covered well with about 3 light coats, and dried almost dead flat very quickly. It seems to be good stuff. With MM enamels becoming harder to get, it may be a good alternative.
Thanks,
Tom
    November 2018
Posted by oldermodelguy on Tuesday, April 23, 2019 8:46 AM
Enamel generally goes over well cured lacquer just fine.
    February 2013
Posted by tomwatkins45 on Tuesday, April 23, 2019 9:03 AM
Obviously I was hoping that's how it was. I'll let it cure a bit more and have at it. Thank you very much.
Thanks,
Tom
    May 2013
Posted by hogfanfs on Tuesday, April 23, 2019 9:15 AM
oldermodelguy
I believe this is true as well. But, if you have some spare plastic, i'd do a small test just to be sure.
 Bruce
 On the bench:  1/48 Eduard MiG-21MF
                        1/35 Takom Merkava Mk.I
Posted by Don Stauffer on Tuesday, April 23, 2019 9:17 AM
Lacquer over almost any paint is a problem- but that refers to real lacquer.  There are now acrylic lacquers, and I don't know whether those are okay over other paints.  Real lacquer thinner is really hot.
    November 2018
Posted by oldermodelguy on Tuesday, April 23, 2019 3:22 PM
It doesn't matter much what the lacquer is under the enamel top coat as long as the lacquer was well cured. As lacquer ( any paint) dries it shrinks. You want that process done. They have different cure rates/dry times.
On another note, lacquer over enamel can be a problem because lacquer can chemically attack the enamel causing wrinkles ( especially if the enamel is fairly fresh) , eaten paint etc, or just soft spots. Hot lacquer is tough stuff. Hobby lacquer less so. Enamel is mild by comparison. Hot lacquer will eat plastic parts if it doesn't dry quick enough, enamel won't for instance.
    February 2013
Posted by tomwatkins45 on Tuesday, April 23, 2019 4:00 PM
Thanks to all . I'm going to let it cure thoroughly and then give it a whirl. In the future, I'll stick with one or the other, but the MM couldn't be found at the time and the Hataka was readily available.
Thanks  Again,
Tom
Posted by Tojo72 on Tuesday, April 23, 2019 4:15 PM
Don Stauffer
Hey Don,question,Your not talking about stuff like Testors Lacquer dull or gloss,I have sprayed them over everything with no problems.
    May 2013
Posted by hogfanfs on Wednesday, April 24, 2019 7:32 AM
Tojo72
Don Stauffer
Same here, I have never had a problem with Testors Lacquer dull or gloss either.
 Bruce
    May 2013
Posted by Greg on Wednesday, April 24, 2019 8:19 AM
Tojo72
I'm also curious.
Not only Testor's Dull and Glosscote, but also all the flavors of Alclad Klear (lacquers, not the aqua acrylic). Sprayed them all over just about everything.
What you say makes perfect sense, now you have me wondering why the above has NOT attacked my underlying paints.
Posted by Don Stauffer on Wednesday, April 24, 2019 9:09 AM
Tojo72
Don Stauffer
True, and I don't know why.  My speculation is that it dries so fast it doesn't have time to affect undercoats.  But that is speculation.  I often spray Dullcoat or Glosscoat over enamel, and have even done it over acrylics, but I try to avoid the latter unless it has dried for many days.
    February 2013
Posted by tomwatkins45 on Thursday, April 25, 2019 4:23 PM
I sprayed a test panel last night, MM RAF dark green over Hataka dark earth. I sprayed it on heavy and wet and it worked just fine. No bubbling, crazing, or etchng at all. Thanks again to all  who responded.
Tom
    May 2013
Posted by hogfanfs on Thursday, April 25, 2019 7:48 PM
Tom,
Thanks for letting us know. Yes
It's good to know there is another option in a paint maunfacturer. I will eventually give Hataka a try.
 Bruce
    February 2013
Posted by tomwatkins45 on Friday, April 26, 2019 6:58 AM
You're very welcome. So far, I've sprayed two of their colors, RAF sky type S and RAF dark earth. Both sprayed beautifully. They remind me a lot of the original, pre-Testor Floquil, but with much less smell. I'm very pleased with them so far.
Tom
    April 2021
Posted by Miata95 on Wednesday, April 7, 2021 9:36 AM
Used Tamiya lacquer primer. Dried 3-4 days. Sprayed Testor's enamel. Still tackey after 3 days. Was this too soon?
Miata95
Posted by Don Stauffer on Thursday, April 8, 2021 9:47 AM
hogfanfs
Tojo72
Don Stauffer
Testors clearcoats are exceptions.  As I have stated previously, I do not know why they work over enamels, but they do.  Testors enamels are my go-to, as are the clearcoats.  I am thankful for the compatibility even if I don't understand it.
BTW, I hear so frequently that Testors paints are out of business, or that they have dropped all enamels.  Neither is true- they have just repositioned the MM line and dropped the military colors.  Both the MM and the plain enamels are more general colors, though they are seeming to cater a little more with MM towards model cars.
Also, I often use glosscoat as a sealer to use something really hot, like non-testors lacquers, over the Testors enamels.
