inexperienced airbrusher - after painting, my parts feel tacky
    March 2019
Posted by Jose Gonzales on Wednesday, May 20, 2020 4:01 PM
Hello all,
I'm working on a kitbash of the Revell 1/96 Constitution and the BlueJacket 1/96 Constitution, and I've just primed and painted my fighting tops and ships boats. Both after priming and after painting, and after drying ~24 hours, I found the parts to be tacky to the touch. I'm using a Iwata neo airbrush, modelmaster enamel primer, and modelmaster classic white. Am I underdiluting or overdiluting the paints with thinner (testors universal enamel thinner)? Or should I just let them dry longer? Perhaps I'm overpainting; I did 3 coats of each, and tried to keep the layers somewhat thin, but may have become overzealous in the last coat in trying to fill in where the primer was showing through.
Thanks!
Jose
    November 2018
Posted by oldermodelguy on Wednesday, May 20, 2020 4:18 PM
About all you can do with an overnight dry of enamel is move the parts to another safe location to dry, especially with their own ( MM)thinner.I've been known to let freshly painted parts done in enamel sit a month. Unless you have a paint dryer or dehydrator you can use as a paint dryer, then enamels you can let sit and air dry for several days to a couple of weeks to cure and not leave finger prints and such when handling for assembly. And then it still needs to finish curing.. Enamel has to cure not just dry. Really depends on weather, humidity, temp and such. I've seen it some what ok to handle in 4 days when thinned with lacquer thinner.
How did they turn out though ?  I bet nice.
Posted by Tojo72 on Wednesday, May 20, 2020 4:34 PM
Sometimes enamels take a lot longer to cure,especially depending on humidity and temperature
    June 2014
Posted by BrandonK on Wednesday, May 20, 2020 4:47 PM
Enamels take a great deal longer to dry in most cases. They tend to be more durable than acrylics, but take a different method to use. For many builders the acrylics are more friendly and allow for quicker building, in many cases. Enamels are also less friendly to your health than most acrylics as well. Overall, if you spray with enamels, have something else to do for several days while you wait for them to cure properly.
BK
On the bench: Alot !
On Deck: Alot more !
    September 2012
Posted by GMorrison on Wednesday, May 20, 2020 5:03 PM
Easily a week, minimum.
Modeling is an excuse to buy books
    March 2019
Posted by Jose Gonzales on Wednesday, May 20, 2020 5:46 PM
Thanks for your replies, everyone! I had used acrylics once before on my old airbrush, but it tended to clog if I left the airbrush for a long time without cleaning it. It did dry fast, but not as durable, tending to peel or scratch more easily. I'll let these sit under some paper towels for a week to keep the dust off.
Jose
    November 2018
Posted by oldermodelguy on Wednesday, May 20, 2020 6:18 PM
Jose Gonzales
Jose
Don't let those paper towels come in contact with the enamel surface this soon in.
What, were you not thinking not cleaning your airbrush ? They really need to be cleaned and don't let that Stynylrez harden up in there or it will be a real chore.
    March 2019
Posted by Jose Gonzales on Thursday, May 21, 2020 2:44 PM
Yes, I've learned my lesson.  I even clear out the airbrush between coats of the same color.
    November 2008
Posted by plasticjunkie on Friday, May 22, 2020 2:46 PM
Wow, a month, a week? I have been using Testors enamels for decades and I mask using masking tape the following day over flat finishes and silly putty after a couple of hours.  Must be the warm Florida weather? This is while using Testors MM flat enamels. The only time I let it cure for a week or longer is if I polish the gloss enamels as in my recently posted F102 or 106 builds.
Your flat  enamel should be dry to the touch  (not cured) in a couple of hours. Gloss enamels take longer to dry.
 I wonder if you did not throughly stir the paint or if you had a bad bottle.
 GIFMaker.org_jy_Ayj_O
    November 2008
Posted by plasticjunkie on Friday, May 22, 2020 2:55 PM
Jose Gonzales
Never put the ab away without cleaning and flushing it. It will not only perform properly but will last a lifetime. My oldest ab is a Badger 150 from the mid 70's and still works like a new one.
Posted by Bish on Friday, May 22, 2020 3:57 PM
I find enamels are touch dry in 24hours max, i leave 48 before masking just to be safe, thats in the UK climate and useing Xtracolor gloss.
''I am a Norfolk man and i glory in being so''
On the bench: AMT STAP/ Youngs Miniatures 1/10th Templar Bust
Posted by Don Stauffer on Saturday, May 23, 2020 9:26 AM
Most primers dry pretty quick, but enamels take several days.   I let Testors gloss enamels dry three days if I do not use my heated drying box on them.  I let the flats dry for 24. If flats are not dry by that time you may be putting on the paint too thick.  Several thin coats give better results than one thick one.  How long did you let the primer dry before the color coats?
