The spec look good, BUT incomplete. It sounds like this made-in-China compressor.
Most of the low cost airbrush compressors sold around the world are either made by Sparmax in Taiwan or various factories in China. I like the Sparmax compressors because of their established track record. You can find them easily in Australia at very reasonable price. Sparmax used to make the compressors for Iwata, Paasche, among others. But it may have changed now.
Many dealers are switching to Chinese manufacturers for the lower end models. You can tell because the Chinese makers double the horsepower quote (but not more powerful motor) for similar compressor. For example, a single piston compressor is 1/8 HP from Taiwan and 1/5 HP from China. Similarly, twin piston compressors are 1/6 vs. 1/3 HP.
The missing item in the spec are:
1. Noise level. The lower the better, but not to exceed 59 dB.
2. Flow rate (L/min) must be specified with pressure (BAR or psi). 25 Litres/min at 4 BAR will be quite good. Stating max flow rate and max pressure separately is typical trick to inflat spec.
3. Manufacturer's name. It will tip off the reliability of the compressor.
