Badger problems
    February 2004
Badger problems
Posted by Winnie on Sunday, April 12, 2009 7:06 PM
So I have three airbrushes, I use an Iwata double action with the tripple action trigger I got at Hobby Lobby for 40% off the other week.
I also have a Badger 155 Anthem, and a Badger 200 (Old school, with vertical cup, not slanted).
This 200 was neglected a little (i did not clean it properly) after using laquers. and after a thorough cleaning the other day, I tried to shoot some of the trusty Mr. Surfacer with it again, but now it pulses slowly. The other two airbrushes are operating normally. I had the thing completely appart, but still to no avail. It keeps pulsing. What am I doing wrong?
Cheers
Harald
    August 2005
Posted by Phil_H on Sunday, April 12, 2009 7:31 PM
Check that the head washer isn't missing or damaged. The head washer is a translucent white/clear washer which fits between the head assembly and the main body of your 200.
If this washer is damaged or missing, it can cause an erratic spray. It's not the only reason that this can happen, but it's a place to start looking.
    October 2008
Posted by Don Wheeler on Sunday, April 12, 2009 9:58 PM
Pulsing is a symptom of a worn needle bearing.  Contact Badger.  They will fix it free.
Don
https://sites.google.com/site/donsairbrushtips/home
A collection of airbrush tips and reviews
Also an Amazon E-book and paperback of tips.
    February 2004
Posted by Winnie on Monday, April 13, 2009 8:25 AM
the worn needle bearing, is that the nxt teflon "tube" in from the front?
Perhaps if I send it to badger, they'll return it with a wrench as well... lol.
I can get both those washers here at michaels, but have some doubts about how to get the one out. The airbrush is very old, and I used to use it lots.
 The other washer is there, but I can't get the tip pieces appart either... wonder what I need to do now.
I cleaned it more yesterday, the cup siphoon tube got a clense with a microbrush, and it really showed what an idiot I'd been. thankfully more paint came out, but it still pulses.
Cheers
H.
    August 2005
Posted by Phil_H on Monday, April 13, 2009 8:34 AM
The needle bearing goes down the threaded hole in the "body" of the airbrush that the head assembly screws into. Under normal circumstances, it's not user-replaceable as it requires a Badger workshop tool to insert/remove it. Sometimes it can be dislodged through overenthusiastic cleaning, but usually it's a RTB job to replace it.
    October 2008
Posted by Don Wheeler on Monday, April 13, 2009 11:10 AM
If you look here, you can read about my experience changing a needle bearing.  But, I recommend you let Badger do it, especially if there are parts of the head assembly that you can't get apart.  Siphon fed brushes create a vacuum in the paint chamber when spraying.  If the needle bearing is worn, air is sucked through it and makes bubbles in the chamber.  This causes the pulsing.  By paint chamber, I mean the inside of the brush where paint flows, not the cup that fits on the bottom.
Don
    May 2005
Posted by Bgrigg on Monday, April 13, 2009 11:32 AM
All Badgers have a lifetime warrenty. I strongly suggest returning it to Badger and having them tune it up for you.
So long folks!
