MikeV wrote: |
You can buy a teflon needle bearing from Coast Airbrush and have them install it in an Iwata. The lacquer will eventually damage the standard needle bearing so put the Teflon one in and you won't have to worry about it. You mentioned pearl powders in the paint, are you sure it's lacquer? The reason I ask is because urethanes are all the rage now with chameleon colors, irridescents, etc from companies like HOK (House of Kolor) and others like PPG. You are correct about some of these paint additives not being cheap. The flip flop (Chamaleon colors) can run $600 a quart. |
Thanks, I was wondering if the teflon packings could be substituted for the standard ones.
As for the paints, I was looking at the example someone used to paint a 1/350 Enterprise Refit aztec patterns...he used HOK clear automotive lacquers, with pearlescent powders mixed in manually. The result he achieved is spectacular, have a look (scroll down to post #194):
http://www.hobbytalk.com/bbs1/showthread.php?t=188494&page=7
The technique he used is described here (scroll down to post #48):
http://www.hobbytalk.com/bbs1/showthread.php?t=246126&page=2
Those powders run about $60 for 2oz! Guess this guy has money to burn, that project must have cost a fortune just for the paint job. It's an approach I'm considering, and I don't know if I'll be able to shell out that kind of scratch for the materials. But if I do, I'll need the appropriate AB to work with this medium. I have a Paasche VL now, and I really want to try one of the Iwata ABs in any case because they seem much less problematic for cleanup, and also seem like overall the better AB.
