Stripping MM Acryl Paint
    May 2008
Posted by BeltFed on Monday, July 13, 2009 4:49 PM
Whats the best way of stripping Model Master Acryl paint?  I tried Alcohol and Windex without luck.  Thanks
    January 2003
Posted by Triarius on Monday, July 13, 2009 6:02 PM
Try a mixture of 25% Simple Green, 25% water, and 50% Windex.
If that doesn't work, try denatured alcohol or ethyl alcohol (Everclear).
Finally, brake fluid is the last resort.
    April 2006
Posted by Jagdwolf on Monday, July 13, 2009 8:51 PM
You can also use Pine-Sol. I found it to remove the paint easily enough.
Posted by MikeV on Tuesday, July 14, 2009 3:36 AM
Super Clean is the best IMHO.
Let the parts soak in it for a couple hours and then scrub it with an old toothbrush.
WEAR GLOVES! Super Clean has Lye in it (Sodium Hydroxide) as does Easy Off.
Second best would be Easy-Off oven cleaner in the yellow can.
    November 2003
Posted by bobbaily on Tuesday, July 14, 2009 1:33 PM
Sign - Ditto [#ditto] I'm with Mike-Super Clean works great-just be sure to wear latex gloves-the stuff is very hard on skin.
Bob
    July 2014
Posted by batai37 on Tuesday, July 14, 2009 5:02 PM
Ditto on the Super Clean. Works on other types of paints as well. It used to be called Castrol Super Clean, but is now simply "Super Clean" Cleaner/Degreaser. Don't confuse it like I did with its weaker cousin Super Clean All Wheel Cleaner.
Posted by MikeV on Wednesday, July 15, 2009 3:19 AM
Good point!
Super Clean is also biodegradable which is good.
