Possible problem with main trigger on Iwata Revolution HP-CR
    July 2007
Posted by JButler on Monday, August 10, 2009 12:45 PM
Hi,
 Just got this as my first airbrush.  Having fun with it, so far.  I did need to clean it the other day and I followed the cleaning tips in the manual and everything went fine with the needle and the nozzle ends.  (Still need to get some lube for the needle.)   However, I think I went a little too far with the disassembly and took out the needle chucking guide and the trigger.  I was able to get it back together and insert the needle, but now the trigger has a little bit of play in it.  When I push it down, I can see that it opens the air inlet on the bottom of the brush, but when I pull up on it, I have about a quarter inch of play in it.  When you pull up on the trigger, does yours have some play in it?  I seem to recall that there wasn't any play in there when I got the gun.  I hope that I don't have to disassemble the air valve.  It doesn't seem to be leaking any air.  Do you evr have to disassemble the air valve area for cleaning?  Thanks for any help that you can give me.
Thanks,
 JB
    August 2006
Posted by HawkeyeHobbies on Monday, August 10, 2009 12:51 PM
Yes! The valve will get dirty and debris from both the paint backflowing along the needle and into the valve area and from contaminents in the air.
Refer to your owners manual for proper break down procedures and reassembly. If you don't have them, they can be found online.
Gerald "Hawkeye" Voigt
    December 2003
Posted by hkshooter on Monday, August 10, 2009 6:56 PM
I've never removed the air valve from my CR and only recently pulled it out of the eclipse for a cleaning because it was sticking.
Get some needle lube and use it. It will help greatly in keeping paint in front of the packing and not in the air valve. After a while a small snugging of the needle packing will restore it's sealling capabilty, also keeping paint out of the air valve area. Don't over do it or the needle will not move freely.
    August 2005
Posted by Phil_H on Monday, August 10, 2009 7:50 PM
Are you saying that you now have some fore-aft slop in the trigger when you draw back on it for paint flow? If this is the case, it has nothing to do with the air valve.
In removing the needle chuck guide, you would have to first remove the spring guide (part 14). When you reassembled the brush, this part may not have been screwed into the body sufficiently.
Loosen the needle lock nut (#16) and turn the spring guide clockwise to screw it further into the body of the airbrush. This should take up the "slack" in the trigger movement. Do not over-tighten as it may lock the trigger closed.
Note that there is some latitude in how far you tighten the spring guide to allow you to vary the spring tension in the trigger.
Re-seat the needle and retighten the needle lock nut.
