Paint Coverage - White over gray primer
    January 2015
Posted by Aggieman on Monday, August 17, 2009 12:02 PM
The only color of primer I have is gray.  If I spray that over the underside of the aircraft I'm building, including in the wheel wells that will be flat white, will the white completely cover the gray?
    April 2008
Posted by smeagol the vile on Monday, August 17, 2009 12:18 PM
Yes
If it doesnt, second coats are allowed
    January 2003
Posted by Triarius on Monday, August 17, 2009 1:46 PM
Put a light coat of silver over the primer first. This will greatly reduce the number of white coats required, and adds almost nothing to coating thickness.
