compatible paint
    February 2008
compatible paint
Posted by myscout on Saturday, August 29, 2009 4:14 PM
I am building a balsa wood/tissue paper model (the way we did it 50 years ago!).  The base coat will be clear dope thinned 50%.  There is a scarcity of colored dope available.  Can I spray the dope base with Model Master enamels?  If not, what type of paint would be compatible with the dope covering?  The dope is necessary to maintain the tension of the tissue after it has been applied and shrunk with water spray.  Anybody ever do this?  P Raino
    November 2004
Posted by Bronto on Saturday, August 29, 2009 9:30 PM
Yes, after the dope has cured you can spray it with MM without any problems.  Only problem you might run into is a weight / balance issue if you are going to fly it.
    February 2008
Posted by myscout on Friday, September 4, 2009 10:40 AM
Thanks for your response.  Myscout
