Mist coats? thinning? huh?
    May 2005
Posted by IceDragon122 on Tuesday, September 1, 2009 9:31 PM
hi guys!  I recently started back into the hobby again (life changes and such) and now have some down time to paint and model again. I recently sprayed on light gray ( MM Acryl) onto my B-17G and i dont like the results. Sorry no picture but let me explain. I dont get an even coat of paint. Some areas are too light and others are too dark. I use MM Acryl with these ratios 2parts paint to 1 part water to 1 part 91% alcohol. After everything is mixed i add one drop of Acrylic retarder. Now the paint goes on a little wet and drys shortly after. It sprays just like the enamels i used to spray, but these paints dont seem to cover the model in one pass. Someone suggested using mist coats and building them up for the final coat. huh?   Sign - Dots [#dots]  Can anyone explain what they are and how do i utilize them? does anyone else spray acrylics in "mist coats".
Also someone on the forums here ( dont remember their name) suggested at one time to only spray MM Acryl right from the bottle w/o thinning it. Never tried it and not so sure how it would work......will this technique give better coverage?
sorry for the novel, but im just in need of some painting help. Cant seem to fix the "must buy more models" problem Whistling [:-^]
Thx in advance!
 -Brian
    February 2005
Posted by RadMax8 on Wednesday, September 2, 2009 12:17 AM
Welcome back to the hobby, IceDragon. I think maybe you are thinning your paint down too much. Here are some tips to use when airbrushing:
  • Use a primer! As a general rule, I always prime. It gives your paint better surface adhesion. I use a rattle can I picked up at Meijer for like $3. Sandable auto primer, dries quickly and covers nicely.
  • When thinning paint, I usually try to get the consistency of 2% milk. That usually sprays the best for me.
  • Light coats are your friend! Don't try to cover the area in one pass. Instead, lay amist coat down. What's a mist coat, you ask? Well, it looks like your model went through a cloud of paint. Very light coat withlittle coverage. From there, you can build on until the paint fully covers your primer.
Hoepfully these tips have helped. It seems like you're on the right track! Good luck!
    August 2006
Posted by HawkeyeHobbies on Wednesday, September 2, 2009 6:28 PM
Ever watch those TV shows like American Hot Rod, Orange County Choppers or the automotive educational shows. Ever notice how they paint stuff. Painting models is done much the same way. When doing gloss colors, the more the layers the deeper the color. Just don't get too carried away and hide all of the subtle details such as panel lines.
Troweling on the paint in thick coats does nothing to enhance the look, more isn't better. There is nothing worse that slapping on a thick coat only to discover you have a major goober on the surface. A light mist coat will help you see any imperfections before you get coverage so you can fix it before you get too far.
Gerald "Hawkeye" Voigt
    May 2005
Posted by IceDragon122 on Wednesday, September 2, 2009 10:22 PM
so what you guys are saying, is to spray the coats on gently and lightly. build up the layers until you get the tone that you desire?
If so, how long should i wait for each mist coat? my acrylics seem to dry quickly once applied. Also I read somewhere that MM Acryl requires Zero thinning and can be shot right out of the bottle? never heard about this, can anyone confirm if it is possible but a better question might be is it worth it? going to do a test tomorrow and try to see if these methods work for me.
Thx Radmax8 and Gerald for your help. Ill try them out Smile,Wink, & Grin [swg]
-Brian
    August 2006
Posted by HawkeyeHobbies on Friday, September 4, 2009 9:11 AM
That depends on the paint, temperature and humidity. Some paints are real slow at setting. Anywhere from a couple of minutes to a half hour...again experiment on a test mule and gain experience. In time it'll be second nature.
