Tamiya Acrylics as base for Alclad?
    October 2007
Posted by Milairjunkie on Sunday, September 6, 2009 2:34 PM
It would seem that gloss black is the preferred base for Alclad on NMF aircraft? Does anyone forsee any issue using Tamiya Acrylic gloss black as a base for Alclad, provided its given enough curing time? If it makes any odds, this is for an all NMF 1/72 B-58.
    September 2003
Posted by Daywalker on Sunday, September 6, 2009 3:33 PM
I have used Tamiya acrylic gloss black as a base for Alclad II with no ill effects.  I have also used Future as a base and that worked well too. Thumbs Up [tup]
Frank
Posted by F105-Thud on Tuesday, September 22, 2009 4:09 PM
Personally, I would use Gloss black Krylon decanted from a can, although I have had good results with Humbrol enamel gloss black. I had a bad experience with Alclad and acrylic undercoat, where the undercoat was left to cure for a month, and the Alclad still cracked!
